Broken Shock
Old Jan 14, 2007 | 05:53 PM
Keeshwah's Avatar
Default Broken Shock
One of my shocks is broken. (I believe, it sqweeks when I push on that side.) How long can I go without a replacement and what are the repercussions?
Old Jan 14, 2007 | 06:09 PM
cherryBox's Avatar
if it is in fact broken, it will be fairly bouncy. the springs support your car. the shocks dampen the recoil of the springs, effectively slowing them down, and keep them from bouncing.
if you hit a large enough bump, the bouncing up and down could cause you to loose control of the car, or worse, cause the wheel to loose contact with the ground, both of which come with severe repercussions.
if it were my car, i'd replace it immediately.
others would say you can go as long as you want, and it's no big deal.
Old Jan 14, 2007 | 06:14 PM
emiller's Avatar
if its broken it will leak. it may just be worn out. either way fix it for your own safety.
Old Jan 14, 2007 | 06:18 PM
Keeshwah's Avatar
What can I do to make sure that its broken? I don't notice the ride being particularly bouncy because most of the roads around me are decent right now.
Old Jan 14, 2007 | 06:21 PM
cherryBox's Avatar
hit it squarely on the side with full force of a 15lb mallet. it will definitely be broken.
i know what you mean. it sounds like it's a candidate for replacement, but not completely gone yet. if you push down on that corner of the car, and it bounces, it's toast.
Old Jan 14, 2007 | 06:23 PM
Andrew1782's Avatar
Is it your front or the back?
I blew both of my rears and they were leaking everywhere. Just look at the base of the shock and spring. If it is vovered in goo that's the oil leaking. If it is your fronts let me know mine are still good and maybe we could work somethying out since I am replacing mine with coilovers.
Old Jan 14, 2007 | 07:08 PM
Keeshwah's Avatar
Back. I anticipated replacing them all eventually since I have Hotchkis springs.
Old Jan 14, 2007 | 07:09 PM
Andrew1782's Avatar
How many miles have you been on your springs?
I know my back blew but I think it was from a scuff that happened on each shaft during the install.
Old Jan 14, 2007 | 07:15 PM
Yanki01's Avatar
i hope mine dont blow by the next couple of months untill i get my Koni shocks. Cant wait for a smoothe ride!
Old Jan 14, 2007 | 08:24 PM
Gortok's Avatar
If its just squeaking, its probably just a sway bar bushing that needs a little lube...
Find the squeak...Don't go replacing parts without KNOWING that they are bad,,,
Old Jan 15, 2007 | 12:11 AM
sciontc_mich's Avatar
how many miles are on your car??
Old Jan 15, 2007 | 12:30 AM
Keeshwah's Avatar
15k total, 10k on the new springs.
Old Jan 15, 2007 | 01:22 AM
wow not a lot of miles at all. i've heard some others saying they had problems with their shocks too (not the one who scuffed the shock when replacing springs).
Old Jan 15, 2007 | 01:30 AM
Macavely's Avatar
ifi you want to check if your shock is clown... go to the side the noise if coming from.. stand facing the wheel... push down overe your strut.. if the sping bounces back and doese compress again.. your good.. but if the spring keeps compressing .. you need to replace them asap..
Old Jan 15, 2007 | 03:40 AM
paul34's Avatar
Wouldn't not replacing a blown strut cause problems for the other struts since you now have an unbalanced suspension?
jthistle
10
May 9, 2016 09:48 PM
babyfac3pn01
Oct 19, 2015 07:24 AM
Darrenohooligan
Sep 26, 2015 07:21 AM
jeremydoc
Sep 16, 2015 11:31 PM
Btp907
Sep 15, 2015 02:54 AM
