Camber Adjustment Kit??
Old Feb 27, 2007 | 09:18 PM
Yorker's Avatar
Default Camber Adjustment Kit??
i have tien s-techs on my tc know and i am an going to buy a camber adjustment kit . i was wondering if i can get away with only buying the front adjustment and not the back. Or are both front and back needed?
Old Feb 27, 2007 | 10:01 PM
SF2K4's Avatar
Actually, I'd say only the back is needed. Some will say you don't need it but I took it to get aligned and only the rears were not put back into the recommended specs.
Old Feb 27, 2007 | 10:10 PM
StealthScion's Avatar
x2.
fronts were fine after my alignment. rears were slightly more negative than the mechanic would have liked to see, but really no big deal.
Old Feb 28, 2007 | 12:44 AM
RollTide's Avatar
Well, that really depends on what you want to do. Do ever intend on tracking the car?
Old Feb 28, 2007 | 02:07 AM
fox's Avatar
fox
I get my work done at PTUNING and they said they have never seen a TC yet to need front camber kits, only rear camber arms to adjust the rear negative camber. Read this post!
https://www.scionlife.com/forums/viewtopic.php?t=162723
Old Feb 28, 2007 | 02:58 AM
RollTide's Avatar
Well, for example, my track tires say that I'm getting positive camber gains in heavy cornering on the outside front wheel. On top of corner weighting, camber is a good solution. But, I don't know that he ever intends to track the car.
You would need front camber adjustments to add negative camber up front because it's not bad at all just lowered, but I don't think that's the concern of this post.
Old Feb 28, 2007 | 03:28 AM
fox's Avatar
fox
I don't think it is either but your right! Negative camber is great for the track!
Old Feb 28, 2007 | 04:03 AM
draxcaliber's Avatar
would you need camber adjustments if you were planning to run hotchkis springs and trd struts on a daily driver?
Old Feb 28, 2007 | 06:35 AM
fsan619's Avatar
Default Re: Camber Adjustment Kit??
I would just spend the extra couple hundred and buy the front and rear set..... it will make your life easier in the long run... I did for my Tein S-techs and I have not had an issue with tires or alignment.....
Old Feb 28, 2007 | 06:45 AM
SF2K4's Avatar
I'm only a degree out in the rear I believe so while I do plan to get the camber kit it's going to wait until summer.
scionhawaii
13
Jun 19, 2015 03:59 PM
jcraff3
Feb 20, 2015 11:41 PM
kleecker
Jan 2, 2015 08:09 PM
Alvie
Dec 12, 2014 05:04 AM
