View Poll Results: DIY Guide or not??
Yes
100.00%
No
0%
Voters: 7. You may not vote on this poll
DIY For Brakes or not???
Old Sep 30, 2006 | 06:43 PM
tc2nut4's Avatar
Default DIY For Brakes or not???
Basically in our tech section we have a front rotor install, a rear rotor install, pad installs and line installs and a bleeding guide but not everything in one... I'm getting ready to do all this in like two hours and I was wondering if anyone wanted me to do a guide for a total brake job and take pics along the way. If not no offense taken if so I'll do it sometime this weekend and post it... so vote away
Old Sep 30, 2006 | 07:47 PM
brian's Avatar
sure! could always use some good pics to go along with an install. the DIY are usually a lot easier to follow with step by step pictures of bolts etc. it's always easier going out there knowing exactly what you're looking at/for!
Old Sep 30, 2006 | 07:58 PM
Max's Avatar
Max
DIYs are always welcome. PM me when done and I will put it in the tech section.
Old Sep 30, 2006 | 08:03 PM
tc2nut4's Avatar
ok looks like I'm bustin out the digi cam lol... and I'll be sure to PM you then Max
Old Oct 3, 2006 | 05:58 PM
sciontc_06's Avatar
pics?
Old Oct 4, 2006 | 10:37 PM
tc2nut4's Avatar
ran into an issue when i finished the process, the breaks weren't the problem like i thought they were so i've been trying to find rides and stuff til i could take it to the dealer... i promise i'll have the DIY up when i figure out whats going on
Old Oct 4, 2006 | 11:16 PM
brian's Avatar
what problem did you run into?
Old Oct 4, 2006 | 11:36 PM
tc2nut4's Avatar
well imagine a sound that sounds like bare pad hitting rotor... but its not... its not the e brake backing plate, its not a seized caliper (pad wear was normal on both sides) and the kicker is this:
grinding noise only occurs AFTER I mount my wheel... im thinking it might be a wheel bearing
olyellr
Sep 28, 2015 10:32 PM
DannyBoy65
Sep 21, 2015 06:23 PM
Subaru86
Sep 14, 2015 12:43 PM
Subaru86
Scion FR-S Aero & Exterior
Sep 14, 2015 12:39 PM
scionsux
Sep 2, 2015 05:30 AM
