front camber
i have question. im slammed on raceland coilovers. my rears are still stock camber but the shop adjusted it. right now i need the front to be negative so i dont rub on my fenders.
i was wondering do i just need a set of front camber kit. it only comes only with two bolts.
or do i need two box. one box comes with two bolts.
There is SOME adjustment from the factory... but I don't know how much you need. The front camber kits are only like $35 or so and yes, just two bolts. I'm at -2 deg with one set. If you REALLY need neg camber you can run two sets and replace BOTH strut bolts on the front.
Just be sure your Toe is correct or the additional neg camber will destroy your tires with a bad Toe adjustment.
thanks. got my aligment done a while ago. they said they couldnt get the front straight need a alignment. they adjusted the rear with the stock. so right now my car is pullin to right a lot. i just order a set of eibach front camber
hopefully it stops the pullin and rubbing.
my setup is racleand coilovers drop about -1 gap. 18x8 35offset 225/40/18 minor rubbing when i turn or turning on the ramps.
scionhawaii
13
Jun 19, 2015 03:59 PM
TheTripleC
Jan 4, 2015 06:46 PM
kleecker
Jan 2, 2015 08:09 PM
