FRONT CAMBER BOLTS!!!
Old Feb 14, 2009 | 01:00 PM
howiedds's Avatar
Default FRONT CAMBER BOLTS!!!
Ok, so i wanted to shell out some money for the F&F II coils, but i have to take a trip to taiwan to see family which cost me a coilover set....sooo
i was searching on camber bolts..didnt really answer anything...
I really want to get rid of my front rubbage... im thinking a camber of 1.75 to 2 should be good..
now i also have tokico shocks...anyone have probs installing onto them?? I know CSOCO had probs with the ingalls bolts...how about the Eibachs or other brands??
Let me know! -Howard
Old Feb 14, 2009 | 04:42 PM
engifineer's Avatar
I run -1.75 up front with one set (in the lower holes) of Ingalls Camber bolts.
Old Feb 14, 2009 | 05:03 PM
CSOCSO's Avatar
heeeeeey.. yeah i had problems with the ingalls camber kit. they didnt fit. I have Tokicos also.
that two pins which goes inside hole wast close enough so i couldnt make the square washer lean flat to the wall of the shocks...
to bend the pins dont use plyer!!!!!!!!! you will brake one of the pins off!
use this:
and do it carefully!
btw how to u call that tool in english?
Old Feb 14, 2009 | 05:04 PM
howiedds's Avatar
vice grip?
so i have to modify the bolts...hmmm i dunno
Old Feb 14, 2009 | 05:05 PM
howiedds's Avatar
anyone else have tokico shocks with camber bolts?
Old Feb 14, 2009 | 05:09 PM
CSOCSO's Avatar
Originally Posted by howiedds
vice grip?
this came up for vice grip:
http://ecx.images-amazon.com/images/...500_AA280_.jpg
so i don think they call it like that.
yes and no... u dont have to modify the bolt... you have to modify that square washer which has two pins...
u put the washer to the hole and that to pins reaches inside the hole but they might not fit right.
But its a cheap thing... 30 dollars for the set of camber bolt?
get them.. take it to a shop if u dont have that tool.. let them try to install it then do the alignment and PLEASE!!! if they dont fit call ingalls and let them know
Old Feb 14, 2009 | 05:11 PM
Crippie's Avatar
1UP Crew
vice grip tend to refer to the pliers that lock. a vise , or table vise would be more accurate.
Old Feb 14, 2009 | 05:14 PM
howiedds's Avatar
CSOCSO, i might try the eibach ones.... if you had trouble with the ingalls..i will prolly avoid them..
Old Feb 14, 2009 | 05:19 PM
CSOCSO's Avatar
let me know how those come out.
Old Feb 14, 2009 | 05:37 PM
mystik's Avatar
CinSity Scions
i installed the progress (spc) front camber bolts. the only thing that seemed weird was the bolt was significantly longer than the stock one so it looks weird when installed, otherwise it fits just fine.
Old Feb 16, 2009 | 02:08 PM
ack154's Avatar
I have the Progress camber bolts and Tokicos. Will be installing them in the spring (they've been on my desk since last fall). Not anticipating any issues, but if I run into something, will probably just switch to another brand.
Old Feb 17, 2009 | 02:18 AM
davedavetC's Avatar
wait a minute...
you are getting teh F&FII coil overs but you want to get camber bolts???
they come with CAMBER PLATES.
Old Feb 27, 2009 | 11:45 AM
howiedds's Avatar
um yeah i just spent 5 grand traveling back to taiwan and buying/giving gifts..etc...no moola for F&F...camber bolts waaaay cheaper... i just wanna solve my rubbage
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
HeyyJose
Mar 11, 2015 02:15 PM
ScionDP
Mar 1, 2015 10:57 PM
TheTripleC
Jan 4, 2015 06:46 PM
kleecker
Jan 2, 2015 08:09 PM
