Front/Rear Weight Bias & Wheel Alignment
I just installed Tein SS-P coilovers and I am planning on corner balancing and aligning my car. I was wondering if anyone could help me with the ideal front/rear weight bias for FF cars in terms of handling.
Also, I was wondering if anyone has done alignment tuning with this car or similar cars for auto-x and could recommend alignment specifications. I would most likely just be adjusting front camber on the go with the camber plates but any input would be appreciated. I believe the following are the factory alignment specs for the tC:
Front (in degrees)
Toe: 0.0 to -0.2
Camber: -0.52 to -0.75
Caster: 3.03 to 0.75
Rear (in degrees)
Toe: 0.3 to -0.2
Camber: -0.9 to -0.5
Front (in degrees)
Toe: 0.0 to -0.2
Rear (in degrees)
Toe: 0.3 to -0.2
Heres a good article on cornerwighting and what kind of values you should be looking for:
http://www.hotrod.com/howto/113_0309_scale/
https://www.scionlife.com/forums/vie...947&highlight=check this out these are the spec's i got when i got my car aligned
eatcrispycreme2
Jan 30, 2015 03:42 AM
cid_mcdp
Jan 5, 2015 02:45 PM
minter66
Dec 15, 2014 01:45 PM
