View Poll Results: TRD's or H&R
TRD'S
40.00%
H&R
60.00%
Voters: 20. You may not vote on this poll
H&R or TRD's on 18's
Old Mar 4, 2009 | 04:04 AM
dqlostsoulz's Avatar
Here is an old pic, 18" rims dropped on TRD's. I dont know if u can noticed how the front is higher than the rear.....
Old Mar 4, 2009 | 04:09 AM
huslindan's Avatar
but was it done settling ?
Old Mar 4, 2009 | 04:11 AM
...this was taken about a lil over a month after I had them installed, maybe longer.
Old Mar 4, 2009 | 04:14 AM
boostdtc3's Avatar
Vogtland Springs from eBay. $153 shipped. 1.6" in the front 1.4" in the back. Even though I'm on 17s there is no sag at all, and I think they'd look good with 18s.
Old Mar 4, 2009 | 04:18 AM
huslindan's Avatar
post pics
Old Mar 4, 2009 | 04:26 AM
Mos_Def's Avatar
i have the problem with the TRD's!!! i would highly recommend getting the HR sport because of this
as you can see, im much lower in the rear than in the front. for this reason, im going to switch out the TRD's for the HR sport. does anyone know if TRD's are warrantable for sagging?
Old Mar 4, 2009 | 06:54 PM
ScionTEK's Avatar
I lowered the contrast to minimum so you could see the gap easier.
Old Mar 4, 2009 | 07:06 PM
huslindan's Avatar
yeah the back is like the perfect hight i want
Old Mar 4, 2009 | 07:23 PM
The rear I liked,but I just wish the front settled the same way...then TRD's would be perfect.
Old Mar 4, 2009 | 07:34 PM
huslindan's Avatar
did you instail yourself? maybe the bump stops werent cut the same ?
Old Mar 4, 2009 | 09:07 PM
ScionTEK's Avatar
The bumpstops were actually only cut for shock travel and that only applied to the front since the rear still had enough travel. It won't affect ride height.
Without the extra travel you'd feel the shock hitting the bumpstop causing a disturbing thud like bottoming out. When you take the suspension appart you'll see what I mean.
I did install my suspension myself, and there really isn't anything in the process that would easily mess up the height since everything locks in and only goes one way. The only thing one could mess up on is maybe stripping/breaking bolts or having them too loose (not having proper torque spec)
Here are some DIY Tech articles with pictures so you can see what all goes on. Front Install
Rear Install
Old Mar 4, 2009 | 09:15 PM
huslindan's Avatar
so do you think if i get the h&r ill rub ? no one is posting any pics of maybe very few people have them?
Old Mar 4, 2009 | 09:18 PM
SW_08's Avatar
yes they would.....
i dont know of anyone with H&Rs
Old Mar 4, 2009 | 09:22 PM
ScionTEK's Avatar
It depends on your offset. Do you happen to know the width of your wheel and the offset?
As a rule of thumb if your offset is close to stock you won't rub. It's only when you run wide and agressively low offset is when you will rub (and you will need fender cut/rolling or pulling and maybe camber adjustments and/or stretch tires if it's really extreme), but if you have a modest drop such as TRD or H&R the rubbing will only happen on dips, on smooth roads you won't be rubbing at all.
And yea H&Rs seems to be a rare thing on SL. I've only seen TRD, Hotchkis, Tien, Eibach, and Tanabe. They are out there, just not alot of people seem to take pictures of them much, if at all.
Old Mar 4, 2009 | 09:29 PM
huslindan's Avatar
idk my offset i have tenzo passion 5 rims 18x7.5 with how do i find out my offset? i looked on the site i ordered from it did not tell me
Old Mar 4, 2009 | 09:33 PM
You can find it behind the wheel. You have to take off the wheel.
Old Mar 4, 2009 | 09:34 PM
huslindan's Avatar
is there any sites i can find that out ? cuz im at school my car is home in the garage lol
Old Mar 4, 2009 | 09:38 PM
It looks as if though the offset is +42, and if I am correct then you will have no rubbing issues.
SW_08's Avatar
i just looked it up and its a 42 offset
Old Mar 4, 2009 | 09:40 PM
huslindan's Avatar
well i also have a wheel spacer in there lol becuase the rims hit the break caliber with out them its like a 1/4 of a inch tho ill have no problem with either springs right?
