View Poll Results: Which Cut Type?
Cut Type "A"
100.00%
Cut Type "B"
0%
Cut Type "C"
0%
Cut Type "D"
0%
Don't Cut It!
0%
Voters: 1. You may not vote on this poll
H-Tech Cut Bump Stops?
Old Nov 10, 2008 | 06:51 AM
wazzu_coug's Avatar
Default H-Tech Cut Bump Stops?
I think I cut my bumpstops too short. So i'm going out to get some new ones. How much should I cut off? Check the Tein manual for a picture of each "cut type."
http://www.tein.com/tech_info/inst/stechu.pdf
Old Nov 10, 2008 | 06:54 AM
Aroddalobster's Avatar
i'm way too lazy to look at the pdf, but i'd cut it in half. and yes, you HAVE to cut it or else you'll bottom out over every bump
Old Nov 10, 2008 | 06:57 AM
wazzu_coug's Avatar
If you've taken a look at the bumpstops. there is a hard black plastic ring that goes around the middle of the bumpstop. I cut just above that point, and am currently bottoming out quite a bit. Thus thinking I cut too much.
Old Nov 10, 2008 | 08:48 AM
TylerC08's Avatar
It's cut A.
Old Nov 11, 2008 | 02:21 AM
xdejablu3x's Avatar
wow i didnt know you had to cut these if you go lower.
Old Nov 15, 2008 | 11:44 PM
emerilnut's Avatar
I cut "A", cuz that's what the sheet told me to do.. Although I really couldn't figure out how many inches that meant cuz the sheet wasn't very clear. If it was .6 inches, then that didn't seem enough... So I basically cut off the lowest bulb part. On the rears, i cut just below the ring, and then cut in the middle of the groove in which the ring sat.
XirtaXa
24
Jan 14, 2025 03:49 PM
Inazuma
14
Jan 8, 2004 01:36 AM
TOY_bB
9
Dec 6, 2003 05:15 AM
Besk_one
Oct 27, 2003 04:13 AM
