help me with front suspension problem...
Old Sep 23, 2008 | 09:48 PM
e246's Avatar
Default help me with front suspension problem...
well i installed my new springs and everything seemed to go well.. But every once in a while when taking off and letting of the clutch i can feel a clunk in my front end and cant figure it out everything seems tight.. It mostly happens when taking off on hills or if i take of harder than normal.. i dont want somthing to be wrong what yall think it could be???
Old Sep 23, 2008 | 09:56 PM
Andrew1782's Avatar
This could me a million things.
I would reccomend you jack the car up and remove the wheels and struts and reinstall again....using a quallity torque wrench.
Inspect everything when you do so....also did you reinstall all of the parts ...ie dust shields on the front struts?
Old Sep 23, 2008 | 09:58 PM
e246's Avatar
ya i installed everything back.. I took my time it took like 2 days of on and off work.. I just cant see what it is, and i work 6 days a week 10 hrs so i dont really have the time to take everything apart again.. this suks
Old Sep 23, 2008 | 09:59 PM
TCpete's Avatar
pls make sure that top bolt on the shock tube has about 4 lines of thread on it... thats usually the first thing that gives problems...
next would be is the spring is properly aligned on the shock...
Old Sep 23, 2008 | 10:04 PM
e246's Avatar
well i looked the top bolt on the shock only has 2 threads but thats all i could turn it???
Old Sep 24, 2008 | 01:05 AM
Andrew1782's Avatar
Try loosing the bolt. Then place a jack under the A arm under the car and compress the front suspension slightly...this will ensure that the shock mount is pressed firmly against the mount on the car. Then using a TORQUE wrench torque to specs. don't count the threads! Only go by the torque wrench reading. Then see if this will work.
Old Sep 24, 2008 | 05:51 AM
TylerC08's Avatar
Yeah my shock bolt only has 2 threads....interesting
Old Sep 24, 2008 | 08:31 PM
e246's Avatar
well what are the bolts supposed to be torqued too??
Old Sep 24, 2008 | 08:40 PM
Andrew1782's Avatar
search through the tech section I cannot recall I did mine over a year ago.
Old Sep 24, 2008 | 08:50 PM
jurassic1's Avatar
From the tC service manual:
Torque: 52 NVm (530 kgfVcm, 38 ftVlbf)
toyotaisme
Jan 10, 2015 10:24 PM
fluxingnation
Dec 26, 2014 04:28 PM
ScionVan
11
Dec 2, 2003 09:37 PM
