Just installed S-Tech's but forgot...
Old Jun 24, 2009 | 11:56 AM
chicotunner07's Avatar
people.............BUMP STOPS DO NOT AFFECT THE HEIGHT OF THE CAR!!
thats why they're calle "bump-stops" because they stop the shock from bottoming out when there is lots of suspension travel!
lol
Old Jun 24, 2009 | 08:04 PM
808tC's Avatar
lol
i know that concept and I stuck with it..but after one of my friends had a problem with his height for his stechs, and he cut his bumpstops, his fronts lowered dramatically. ask fliphm00b. one of our other friends still had uncut bumpstops on stechs (l0st) and hes not as low as fliphm00b so ill go with personal experience and say that cutting it lowers the stance.
Old Jun 24, 2009 | 08:09 PM
rosedaleny806's Avatar
see now i know im not going crazy.
Old Jun 24, 2009 | 08:40 PM
jonathan110987's Avatar
maybe by bottoming out with cut bumpstops lowered the stance with stechs.. by wearing the shocks different? i dunno.. all i know is that it seems lower with cut bumpstops
Old Jun 24, 2009 | 08:45 PM
x2 on me not being crazy
Old Jun 24, 2009 | 08:55 PM
AcidDrop's Avatar
2 yrs with s-techs and stock shocks with uncut bump stops and it's still good, i do have any extra set of bump stops that i might cut and see if it does or does not go lower.....just to kill time as well LOL.
Old Jun 24, 2009 | 09:28 PM
your all crazy!! LMAO
its possible that the springs were not sitting right on the top or bottom mounts, and when they happened to cut the bumpstops, the ride lowered some more, lol
if you look at your struts, you can see that the bumpstop is just sitting there, doing nothing..........waiting for the day you run into that huge pothole! lol
Old Jun 25, 2009 | 08:03 AM
Phobboi's Avatar
Not cutting your bumpstop increases your risk of cracking it when your lowered.
Old Jun 30, 2009 | 07:28 AM
Diluvium's Avatar
from what i have observed you can cut the rear strut bumpstoppers and your rear will lower down which is highly unrecommended to attempt, but i definitely DOUBT the fronts will drop like that because, the bumpstopper moves freeely up and down the struts rod....
Old Jun 30, 2009 | 07:45 AM
Diluvium's Avatar
my guess is whoever believes that cutting the bumpstops lower their car, mostly like your car is very close to bottoming out anyway so cutting will add the extra play with very low, extra stiffened springs to prevent sagging or shocks from bumps. so, you guys must be bottoming out ALOT to DEFAULT and notice the cheapest solution is to cut the bumpstops
Old Jun 30, 2009 | 02:05 PM
then why do hotchkis come with replacement bumpstops that are half the size of regular bumpstops?
Old Jun 30, 2009 | 02:38 PM
x3 on me not being crazy
Old Jun 30, 2009 | 05:45 PM
Diluvium's Avatar
like i just said, installing hotchkis springs ONLY is no different then h or s tech that dont provide bumpstops knowing you would bottom out anyway. and hotchkis lowers more then H techs. also those replacement bumpstops are for the front, right?
Old Jun 30, 2009 | 05:46 PM
both front and rear oh hotchkis.
Old Jun 30, 2009 | 05:59 PM
Diluvium's Avatar
if you personally get to install them yourself, then you'll notice the rear strut bumpstops sits in place of the top strut mount, so if the rear bumpstops are smaller ur top strut mount should mount assemble further down, giving it the "complete 2" drop" as advertised. for the front it is IMPOSSIBLE to drop your car by cutting the bumpstops.
LOOK under your front struts, do you see the BUMPSTOPS? most likely not cause that black rubber sleeve is covering it which is holding on to the bump stops. you can slide the bumpstop down an observe and thats self explanatory. if you do slide it down, slide it back up the sleeve or your bump stop will crunch in the sleeves aswell when u bottom out.
Old Jul 21, 2009 | 11:38 AM
kovz34's Avatar
Haven't been around for a few weeks to check back on my thread... but looks like I stirred up quite a commotion.
Well the car is riding great after having these on for a month now. I think it did settle down a bit more, I will try to get some pics up when the weather is better and I wash the car. It looks the same as everyone else that posted pics with stock wheels and the s-techs.
Old Jul 21, 2009 | 03:03 PM
getaforknjob's Avatar
I don't have bump stops either and I'm problem free.
Old Jul 27, 2009 | 08:11 AM
ktothesass's Avatar
hmm...ima be installing mine soon. i was wondering the same question. maybe no bumpstops then
Old Jul 31, 2009 | 05:21 PM
09crimsontc's Avatar
i dont know why people install stechs with stock rims looks redick.
Old Aug 4, 2009 | 02:37 AM
superwhitecoke's Avatar
imo stockies with s techs look sexy
i get my s techs put on tomorrow
how long did it take for you kovz34
