Negative Camber after TRD Springs for Rear wheels?
Old 01-23-2005 | 05:36 PM
JEDI's Avatar
Default Negative Camber after TRD Springs for Rear wheels?
Like the title says, did anyone who did the TRD springs w/o the struts end up with a slight negative camber in the rear?
Old 01-23-2005 | 06:01 PM
yesti's Avatar
one would assume that lowering the car would indeed induce negative camber. is it enough to cause uneven tire wear? if you keep it under 2" probably not.
Old 01-23-2005 | 07:12 PM
lvnurs9's Avatar
I have a small camber as well on Teins. It's normal.
Old 01-23-2005 | 10:18 PM
Tc808's Avatar
Yup had a negative camber. Don't know if it would affect tire wear but I had an alignment done anyway.
Old 01-24-2005 | 06:41 PM
sdparks's Avatar
Default Re: Negative Camber after TRD Springs for Rear wheels?
You will have increased negative camber as a result of lowering the car. However, there is enough adjustability in the tC's suspension to return the camber to normal. The alignment specs for the TRD springs are the same as stock.
Old 01-25-2005 | 05:06 AM
JEDI's Avatar
Thank you fro the responses.
I will have the alignment checked. Its good to know nothing is wrong.
Old 01-30-2005 | 06:47 PM
chipmOnk's Avatar
i just got mine aligned a few days ago... the rear two were off about a degree each... front were okay though
Old 01-31-2005 | 10:13 PM
Guest
Guest
Posts: n/a
after springs settle the alignment will be off. There are a lot of alignment adjustments on the tC. I would recomend an alignment after the springs settle. Shoot I wish I had the alignment adjustments on my xB like the tC has.
Old 01-31-2005 | 10:24 PM
squirrel's Avatar
Cars w/ independent rear ends will have some negative when lowered from stock height. That's just the nature of the engineering. Unlike xAs and xBs that solid rear ends.
DJ_FroZone
25
05-30-2019 07:17 PM
terrye
07-11-2015 11:54 PM
JPuehl
01-10-2015 01:01 AM
kleecker
12-31-2014 09:42 AM
minter66
12-15-2014 01:45 PM
Quick Reply: Negative Camber after TRD Springs for Rear wheels?
