Negative Camber pics please!!!
For anyone who is running Negative Camber on there tc can you please post up pics of it. please include with your pic.
1) Degree of camber
2) What you toe is set at
3) How tire wear is
Thank you very much.
__________________
1) Degree of camber
3) How tire wear is
__________________
I'll have to get pics at some point later...
But here's what I'm running from my last alignment:
LF After|Setting|RF After
-1.93*|Camber|-1.92*
3.26*|Caster|3.29*
-0.02*|Toe|-0.03*
LR After|Setting|RR After
-1.50*|Camber|-1.19*
0.28*|Toe|0.20*
Tire wear is normal. I have rotated them and need to do it again (autox is a killer on tires... so I'm trying to keep it even).
____
3.26*|Caster|3.29*
-0.02*|Toe|-0.03*
0.28*|Toe|0.20*
____
you might want to try https://www.scionlife.com/forums/sho...d.php?t=138292
This is 18x9.5 et 38 (before i put 5mm spacers and jizz) w/ -3.4 camber in the rear
This is -1.7 in the fronts
and heres a lower quality picture taken by my sidekick.. (this is with -3.2 camber)
Also I havent noticed a significant difference in the tire wear they all look good to me, as i check them every few weeks.. (have stock specs for toes)
well it will "chow" the tires on one side very very slowly,, but if the toe is off that is what helps in chewing the tire fast.
and only -1.7 up front cuz that was the max the tein ssps i had maxxed out at.
Subaru86
Jul 31, 2015 04:33 AM
Subaru86
Jul 31, 2015 04:00 AM
