noise plz help
Old Nov 14, 2009 | 09:10 PM
speedy000's Avatar
Default noise plz help
i have a set of hotchkis sway bars and recently i have been hearing a pop/knock noise from the rear. i have a question...i did take an endlink off once and put it back on but for some reason i think i put it on upside down. does this matter or are both sides of the endlink the same?
also tightening the endlinks i didnt find any torque specs for that but u can only tighten so much before the endlink spins and doesnt tighten anymore.....anyone have an input or suggestions?
Old Nov 14, 2009 | 10:20 PM
willy213's Avatar
Have you upgraded your suspension at all or is the sway the only mod in the rear?
Old Nov 14, 2009 | 10:40 PM
speedy000's Avatar
I have the trd springs.
And the hotchkis sway bar set.
The pop first started when I turned left so I took it off the stiff setting and put it soft and now I hear it at all times....
Old Nov 15, 2009 | 01:05 AM
speedy000's Avatar
Ok so Fixed the problem!!!!
The endlinks don't appear to be different but if u put it the wrong way it doesn't tighten all the way the endlink spins as u turn it not letting u tighten it all the way. That cause the noise. So future refrence to anyone to takes theirs off make sure to pay attention.
Old Nov 15, 2009 | 01:30 AM
engifineer's Avatar
That is why it has a hex key hole in the end of it. You are supposed to hold that with a hex key while you tighten the endlink nut. That is the way the endlink is supposed to be installed.
Old Dec 8, 2009 | 12:31 AM
TC_Rollin's Avatar
I have the same issue I will deff look that up!
kb1sxv
Oct 21, 2015 05:00 PM
Klashan
Sep 24, 2015 12:39 PM
Andreas24
Sep 15, 2015 02:10 PM
mcnick0495
Scion tC 2G ICE & Interior
Sep 8, 2015 02:58 PM
alexbarspin
Sep 3, 2015 02:04 AM
