Painting Brake Calipers
Old Mar 8, 2008 | 02:31 AM
breaux_tC's Avatar
Duplicolor Metalcast Blue FTW
Old Mar 8, 2008 | 05:10 AM
tCeeder's Avatar
Originally Posted by zzzBrett
Yea that looks great.. I just finished putting the whole caliper assembly back together. I had the whole thing off, just the brake line left, then couldn't figure out if i just unscrewed the brake line would the fluid come out, or what.. so i decided to rotate my tires and lubricate the brakes today, and leave the painting for another day. I was going to spray but yours looks nice, so maybe i'll just do the kit.
Brett
yes fluid would come out as well as air entering the brake line and caliper, resulting in you needing to bleed your brakes.
I am ready to bleed the brakes, but would the fluid just continue to come out, or would it stop at some point? Would I have to buy more brake fluid and refill the container under the hood?
brake fluid would continue to come out (slowly) unless you plug the line. when i installed my SS brake lines they came with rubber line plugs to temporarily plug the lines so fluid doesnt keep leaking. however you will need to add some brake fluid after you're done bleeding them. good idea to fill it to the very top, then bleed the brakes, then once you have removed all the air from the lines, check if the fluid reservoir went down enough to have to top it off again. one container (1pint) will be enough, youll use about half or so. if you were to remove ALL the fluid from all the lines and calipers, it would take 3 pints/1500ml to completely fill the entire reservoir and lines back up.
RY_TC07
Jul 18, 2017 05:18 PM
Squishface
Sep 15, 2015 06:51 AM
jswtex
May 16, 2015 02:34 PM
Cmstone202
Scion tC 1G Wheel & Tire
May 12, 2015 06:58 PM
TheTripleC
Jan 4, 2015 06:46 PM
