Passanger Side Front Wheel Vibration and Uneven Brake Pad Wear
Old Feb 2, 2011 | 03:42 PM
Zensmith's Avatar
Default Passanger Side Front Wheel Vibration and Uneven Brake Pad Wear
Hi all.
I recently started getting a vibration that appears to be originating from my front right wheel. The vibration only appears around 40-45 MPH and stops around 50-55 MPH.
At first I was thinking it could be a balance issue, but I noticed that my front right brake pads are wearing SIGNIFICANTLY faster than my front left pads. I have also noticed a ton of brake dust on the front right rim.
Any ideas? Are these two issues related, or could it be a stuck caliper AND a out of balance wheel?
Thanks for any ideas!!
Old Feb 2, 2011 | 06:21 PM
emptystreets130's Avatar
Sounds like a warpped rotor. Caliper could of been sticking.
Old Feb 2, 2011 | 06:25 PM
Zensmith's Avatar
I thought it might be a warped rotor, but it does not vibrate when I hit the brakes.
Old Feb 3, 2011 | 06:09 PM
PeArLwHiTe07tC's Avatar
go to an empty parkin lot and hit the brake and let off the wheel. if the car steers in any other direction other than str8, than u know its a caliper issue. as for ur vibration, its possible u may have a bad wheel bearing, or something else starting to let go. usually a tire vibration wont go away, it usually gets worst at higher speeds.
Old Feb 3, 2011 | 06:11 PM
Bad tie rod ends?
fur_pig
Mar 20, 2020 04:28 PM
swrdply400mrelay
Jan 9, 2015 01:10 AM
minter66
Dec 15, 2014 01:45 PM
umnitza
Dec 1, 2014 06:26 PM
JDMxB
13
Dec 23, 2003 04:23 AM
