Please help!? Ground Control spring owners?
So I bought these coilovers on here from Tctunerz, but I don't really know which pieces go togeather, and I can't find a pic anywhere. Yes I searched. Please help. Thank you!!!!
I don't think the DIY mentioned that the rubber o-rings go over the stock strut so that the red threaded collar is tight. You'll notice if you just slide the collar over the strut with out them it will be loose and wiggle around. You DO NOT want this.
You can even wrap the strut with electrical tape if you don't have enough rubber o-rings or if they are too tight.
probably not to hard an install on those,they are pretty much exact same ocncept as lowering springs.
once the strut and spring are apart,put the screw ring on with the orings,put spring on,put bumpstop on and stock pillow block and tighten.
basically these just alow you to adjust ride height if you want,they look pretty cool though.....wonder how they ride.
DJ_FroZone
25
May 30, 2019 07:17 PM
scionlife
371
Jun 2, 2015 11:00 PM
Beesh
Jan 9, 2015 06:30 PM
