Question about TRD vs OEM Shocks.
Old Feb 7, 2008 | 01:48 AM
TinmanTC's Avatar
Default Question about TRD vs OEM Shocks.
I currently have have TRD Springs/Sway with OEM shocks.
How much of a difference would I notice if I upgraded to TRD Shocks? And in what way?
Because when my stockers blow, not sure if I get some used OEM's from the classifieds, or if I should fork over the $$$ for trd.
thanks
Old Feb 7, 2008 | 01:51 AM
draxcaliber's Avatar
stiffer shocks are more responsive, and lower and will greatly improve handling and braking
Old Feb 7, 2008 | 01:56 AM
TinmanTC's Avatar
Worth the money?
Old Feb 7, 2008 | 02:14 AM
well, if your going to replace your oem shocks anyway, what is the price difference for oem shocks versus trd ones?
but yes, worth the money.
Old Feb 7, 2008 | 02:20 AM
TinmanTC's Avatar
Well, Im sure I would be able to score some used OEM shcoks from the classifieds for no more then 100$.
TRD's are 450$.
Old Feb 7, 2008 | 02:32 AM
you aren't limited to just trd ones, there are koni yellows and tochiko also.
Old Feb 7, 2008 | 03:10 AM
Sciontistical_One's Avatar
Drax, I could be wrong, but I thought shocks didn't determine your ride height, your springs did, are you sure ?
Old Feb 7, 2008 | 03:12 AM
springs have a much bigger impact on ride height but the fact is that the trd shocks and struts are shorter than the OEM ones. so if you put stock springs on trd struts, your tc would be lower than OEM springs and shocks would be.
Old Feb 7, 2008 | 03:37 AM
Good point Drax, and since Tinman is already on TRD springs and shocks, he might not see a significant difference in height, right?
Old Feb 7, 2008 | 05:01 AM
TinmanTC's Avatar
Yep. Might be a little bit, but nothing significant.
Old Jan 2, 2009 | 07:57 PM
TinmanTC's Avatar
bump..
Not sure if I should get low mileage oems used or fork over the dough for some trd's.
ANy suggestions?
Old Jan 4, 2009 | 07:37 PM
XIEmperorIX's Avatar
I would just go ahead and upgrade to the TRD's..i'm running TRD springs/struts and i love it...been on that set up for roughly 10k miles
Old May 23, 2009 | 08:56 AM
TinmanTC's Avatar
more opinions please....
Old May 23, 2009 | 09:25 AM
--Final_Wrath--'s Avatar
I wouldnt buy used ....Im not sayin to go with a certain brand, just sayin that its worth it to just get new ones..
Old May 23, 2009 | 05:17 PM
SoulXquisite's Avatar
-im getting my td springs/shock,struts install this tuesday ill let ya know hahahaha
Old May 23, 2009 | 07:24 PM
TCyalater's Avatar
sorry I dont mean to thread jack but did I hear this right...?
When you're running TRD springs with stock shocks, you will still not have the total drop untill you upgrade to TRD shocks?
the reason Im saying this is because im wanting to go a tad lower in height but I dont want to have to buy another set of lowering springs to be .5 or so lower. If the TRD shocks lower the car more that would be awesome. Are there shocks out there that are shorter than TRD's?
Old May 23, 2009 | 08:28 PM
-well i dunno if it is gonna be lower, ill take before and after pics to see if there is more of a difference. as far as other lower shocks? not sure, but you can check tokico or konis i think
Old May 23, 2009 | 11:15 PM
yes, it'll drop some more...nothing crazy, but sounds like something you would like
Old May 24, 2009 | 02:06 AM
TCyalater's Avatar
saweeet, which set of shocks do you recommend?
Old May 24, 2009 | 02:31 AM
Well most peeps would suggest the Trd ones since you already have the springs....So you can have a "true" Trd drop...Theyre just kinda pricey if you ask me....but worth the money
