Rattle Noise When at Idle
Old Feb 14, 2012 | 06:26 PM
cashvillem1's Avatar
Question Rattle Noise When at Idle
So I been having a rattling noise issue. When I turn on the car in the mornings, 30-35 degrees F. I hear a rattling noise coming from the driver side engine bay. The rattling continues through the warm up of the car usually until RPM's are around 1k. Once the car is warmed up the rattling stops, but when I put the car in reverse( 5 Spd) and let the clutch out the rattling comes back but when i push the clutch back in it goes away. At the end of the day the rattle does not come up, only when i put the clutch in. It feels worst in the cold mornings but at the end of the day you can barely hear it. Idk what it could be.. any input? thanks. Mods are : HKS axle back.
Old Feb 14, 2012 | 09:54 PM
Kidbarillas's Avatar
Could be sum thing in the trany how old is ur clutch may be it coming apart cuz that happen in a car i had clutch broke into pieces
Old Feb 15, 2012 | 02:21 AM
10gxiong's Avatar
Have you checked your waterpump?
Old Feb 20, 2012 | 03:21 AM
Actually my water pump is leaking but the leak has seized. The noise is not coming from the water pump. It sounds like a loose or broken shocks, or engine mounts but the shop said my motor mounts are good so are my shocks..when I go on dips or pumps it makes it even more. got 90k miles got a new clutch at 30k miles. any input?
Old Feb 20, 2012 | 10:37 PM
SC06TC's Avatar
I forgot the name of it off the top of my head but i think you may be hearing the gas recycle valve, you can trace it back from your intake. It usually makes a loud ticking or rattle if you will after a few years....kinda like that old school popple toy. i have not replaced mine yet and have been driving with it for a while now. It got louder too with CAI/E/TB/I install. Just an idea.
Old Feb 21, 2012 | 07:47 PM
mxyooji's Avatar
clutch IN and noise = throwout bearing.
clutch OUT and noise = input shaft bearing.
steeze69
May 24, 2021 02:57 AM
kb1sxv
Oct 21, 2015 05:00 PM
mikeac
Sep 15, 2015 03:24 PM
Andreas24
Sep 15, 2015 02:10 PM
mcnick0495
Scion tC 2G ICE & Interior
Sep 8, 2015 02:58 PM
