Scion tC Coilover Info Chart
Old Feb 21, 2008 | 11:52 PM
ddplion's Avatar
Default Scion tC Coilover Info Chart
I have been working on this for a while.
I have taken info from a number of other
charts and I have looked up a lot of the info myself.
I have tried to make sure that there was at least 2 sources
but I may have gotten some of it wrong.
Anything to add .............. ?
By ddplion at 2008-02-22
Old Feb 22, 2008 | 12:21 AM
2_much_tc's Avatar
i think the Megan Racing Coilovers are 32 way adjustable...
Old Feb 22, 2008 | 12:29 AM
Ace83's Avatar
Ronin Scion
good job man, thats a good research.. did you check on the sticky on suspension buyers guide? I think it needs to be updated though.. keep you list updated.. and yeah tein ssp have 16 level dampening/ 32 optional w/ EDFC
Old Feb 22, 2008 | 12:34 AM
ddplion's Avatar
so the ssp come w/ 16 but when you add the EDFC is doubles to 32?
I'll double check both of those and add them.
Thanks for the help
Old Feb 22, 2008 | 12:36 AM
Ace83's Avatar
Ronin Scion
Thanks for the help
default on the EDFC is 16 but you can change the setting so it will let you adjust up to 32, i guess it adjusts halfway so it doubles..
Old Feb 22, 2008 | 02:44 AM
ddplion's Avatar
is this setting change only on the edfc. abother word if you don't hace edfc only 16
Old Feb 22, 2008 | 09:26 AM
ScionGT35R's Avatar
Watching this one!!!
Old Feb 22, 2008 | 11:34 AM
Ace83's Avatar
Ronin Scion
Damper adjustments without the EDFC is done by clicks (16 settings), with EDFC 32 adjustment option, I think it does finer adjustments so it adjust in between clicks or halfway adjustment
Old Feb 22, 2008 | 01:56 PM
ddplion's Avatar
I have updated it.
I am going to keep looking into this but if anyone has anything to add ....
Please Help
Old Feb 23, 2008 | 02:15 AM
ddplion's Avatar
bump for more info
Old Feb 24, 2008 | 09:36 PM
ddplion's Avatar
bump for more info
Old Feb 25, 2008 | 02:48 AM
davedavetC's Avatar
good info on the H&Rs, i was curious as to my max drop
will find out how it looks soon :D
Old Feb 28, 2008 | 10:37 PM
R2D2's Avatar
Old Feb 29, 2008 | 02:29 AM
ddplion's Avatar
Originally Posted by R2D2
so what is your Idea?
Old Mar 26, 2008 | 12:23 AM
mystik's Avatar
CinSity Scions
B&G RS2 Coilovers are have a monotube construction and is 18 way adjustable for dampening. just incase you needed anymore info on there hahha.
Old Mar 29, 2008 | 01:35 PM
tCeeder's Avatar
any more updates on this?
as for spring rates, the closer to stock, the less harsh the ride usually?
Old Mar 30, 2008 | 04:02 AM
ddplion's Avatar
Yeah... the higher the number the stiffer the ride.
Closer to stock is more comfortable but also has more body roll.
I have not added the info B&G's but I will. Still looking for more info if any one wants to help out.....
Old Mar 30, 2008 | 04:05 AM
tCeeder's Avatar
I think the H&R info is a little off, i found this on an old thread:
Tein Basic - ~$779 (1.4"-2.7"F/1.4"-2.6"R) (392 lb/in F/ 559 lb/in R)
Tein SS - ~$1079 (same as basic) (same as basic)
Tein SS/P - ~$1189 (same as basic) (same as basic)
Progress - ~$979 (1"-3"F/1"-3"R) (250 lb/in F/ 350 lb/in R)
H&R - ~$1050 (.75"-2.7"F/.75"-2"R) (estimate 200 lb/in F / 325 lb/in R)
Tanabe Sustec Pro S-OC Type II - ~$879 (3/8"-2"F/ 3/8"-2 3/8"R) (336 lb/in F/ 448 lb/in R)
Tanabe Sustec Pro S-OC - ~$1059 (same as Type II) (same as Type II)
seems like H&Rs and then Progress CS1s are the closest to stock, for smooth ride quality that is.
Old Mar 30, 2008 | 04:16 AM
ddplion's Avatar
THANKS man!
I'll look into that info and update my chart. WHen I was thinking about getting CO's those were the exact two that I was thinking about getting. I just went for a ride in a friend of mine's car that has the H& R's and they road great. Of course they were stiffer but not as stiff as ppl make it out to be. It stuck right to the road and over bumps you can feel them but from what I had read on here I thought that it was going to be rediculious. They felt great.
Old Mar 30, 2008 | 04:22 AM
tCeeder's Avatar
np!
yeah, i'm upgrading to CO's soon and am stuck between H&R and Progress CS1. after searching a good bit, it seems both are very close in terms of ride quality and it just comes down to personal preferance. i read nothing but good things for both each of them on the TC, whereas the Teins feel like you're riding the flintstones mobile.
