shocks and springs
Old Mar 29, 2005 | 07:41 PM
bballplayer0968's Avatar
Default shocks and springs
if i get the trd springs is a good idea to get the shocks as well or is that just a waste of money??
Old Mar 29, 2005 | 08:01 PM
onebadassdx's Avatar
always get both, if you only get springs, your stock struts are driving on borrowed time
Old Mar 29, 2005 | 08:24 PM
JasonH's Avatar
The TRD springs are made to be used with the stock struts or the TRD struts. Sure, the stock ones will wear out a little sooner, but they're not going wear out that much sooner.
Old Mar 29, 2005 | 08:55 PM
Sparks_Scion_TRD_Parts's Avatar
Default Shocks and Springs
Whatever you decide, we still have some specials on the Springs and Shocks from TRD and the Hotchkis Springs and Sway bar sets.
http://www.trdsparks.com/displaypart...1&parts_id=586
Ken
www.trdsparks.com
Old Mar 30, 2005 | 11:11 PM
Mr_Meaty's Avatar
If you get the TRD springs, you dont' have to worry about the shocks until after you warantee is over. But since they are designed to work together, I dont' see why they wouldn' last the 3 years through the warantee.
Old Mar 30, 2005 | 11:17 PM
johnnyTCblaze's Avatar
How do you know when your shocks go out?
Old Mar 31, 2005 | 01:24 AM
neuromonic's Avatar
*sigh* This has been discussed to death. I did a search and below was one of the many threads that came up.
https://www.scionlife.com/forums/viewtopic.php?t=44557
Old Mar 31, 2005 | 02:12 AM
r1mirostc's Avatar
nevermine shocks and springs...wasting money...get full suspension...TEINS baby...
Old Mar 31, 2005 | 05:24 AM
Mr_Meaty's Avatar
Hey, I got a question for you. If you get adjustable coilovers, like the Tiens, do they replace the springs and shocks? Or do they go around the existing shocks?
Old Mar 31, 2005 | 06:09 AM
reagulator's Avatar
coilovers replaces them
Old Mar 31, 2005 | 01:29 PM
Mr_Meaty's Avatar
That's what I thought. And I guess that would justify their much higher price tag. The reason I ask is because I have seen alot of threads asking which shocks to use with tien basics. I guess they must have ment just the tien springs.
So then, with coilovers, do you get that bounce in the ride like you do with a 2" drop on stock shocks?
Old Apr 1, 2005 | 12:54 AM
gtalord's Avatar
one more question to add to this list...
How about the ground-control coilovers, do they also completly replace the shocks and springs?
Old Apr 1, 2005 | 06:01 AM
neuromonic's Avatar
That bounce comes from a stiffer spring coupled with the wrong (usualy factory) dampers. If the spring rate is too high the damper will not be able to do its job because the spring is overpowering it, resulting in a bouncy ride. I reccomend buying the TRD spring/dampers as a set if you can afford it. (You should save on labor if you are having it done at a dealer.)
Are you looking to increase the handeling of your car, or just make it lower to the ground?
Old Apr 1, 2005 | 06:09 AM
neuromonic's Avatar
Not if you are talking about something like this. This is a spring and spring-perch that fits over a damper (shock) to provide adjustable height.
(edit: sorry that was supposed to be one post. i'ma )
Old Apr 1, 2005 | 11:09 AM
gtalord's Avatar
cool thanks neuromonic, looks like it's teins for me
Old Apr 1, 2005 | 01:37 PM
Mr_Meaty's Avatar
Thanks! That's exactly what I thought.
I am going for handling and looks, so I just have the TRD Springs cause there are no after market shocks yet. So the stock shocks should last until my warantee is up, then I'll get some coilovers. There should be plenty more out by then.
Old Apr 12, 2005 | 04:33 AM
verditsgerman's Avatar
another question... the TRD shocks won't lower the ride any more than the TRD springs with stock shocks will they?
Old Apr 12, 2005 | 05:03 AM
reagulator's Avatar
nope.
Old Apr 12, 2005 | 07:00 AM
quitate54's Avatar
anybody know how much stiffer are the TRD shocks...???
goatbelly
Jul 12, 2015 10:13 AM
carid
Feb 12, 2015 11:54 AM
fluxingnation
Dec 26, 2014 04:28 PM
swtbabiboi4u
Oct 13, 2003 04:38 PM
swtbabiboi4u
Oct 10, 2003 01:40 AM
