sidewall height
ive noticed different brands have differnt sidewall hieghts........im looking for the lowest profile on a 225/40 18 tire.....pics are helpfull, i have a tein Htech drop about 1.7 inches. id like any helpfull input, i really dont want to have to go to a 215/35-18 or a 225/35-18.
yeah, some ive noticed are different height.......kuhmos are the worst,good tires, ive had them, but thier sidewall is higher then others. ive narrowed it down to falkens, bfgoodrich or nittos. im looking for a good all around tires wet and dry traction.
Got measurements to support that claim? Tire sizing is controlled by DOT. It would be really bad for a manufacturer to claim the tire is a size that isn't the same as the other manufacturers. Tread width can vary, but overall carcass width and aspect ratio are not up for interpretation.
i already know that, but some tires appear to look shorter then others, that is what i ment and should have clairified that in my first statement
........some of you guys take everything too literal, like im off to sue someone and im looking for "facts to support my case" . relax. its a personal observation that i have noticed lately about tires..........so settle down
tires with the same width, aspect ratio and diameter should all be the same size. i've never seen a one tire look taller than another with the same size specs. thats like saying some 17" wheels are taller than other 17" wheels (of the same width). maybe youre comparing a tire with more tread and one with less tread. or you could be looking at a tire thats been stretched to fit a wider wheel, which does thin the appearance of the sidewall.
certain wheel designs can make tires look fatter or thinner. to me, thin/narrow spoked wheels make tires look fatter than thicker spoked wheels.
Originally Posted by daewonder
you mean, not all 40 series tires are the same height? hmmm.
If the rims are narrower or wider than the one used for the official measurements, they may be taller or shorter respectively. For the tire to perform best, you should use the recommended rim width. This is why I went with the GN+ for 245s despite being quite a bit heavier than FN01RCs. It all has to work together...
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
Subaru86
Jul 31, 2015 04:33 AM
Davyo
Jul 29, 2015 05:53 AM
