strut bars
Old Jan 25, 2009 | 06:48 PM
superwhitetc89's Avatar
Default strut bars
has anyone seen a strut bar that goes across the floor in the backseat?
Old Jan 25, 2009 | 06:51 PM
rosedaleny806's Avatar
there actually is one, I saw it on ebay but it looks weird lol, and there's also the one that goe in the trunk area.
Old Jan 25, 2009 | 06:52 PM
has anyone ever bought this part and used it?
Old Jan 25, 2009 | 06:59 PM
AcidDrop's Avatar
you mean behind the front seats, yes i have seen it on ebay but not in person. not sure if it will even stiffen up the car at all, but they do sell 4 different type of rear strut bars though.
Old Jan 25, 2009 | 07:19 PM
milanshere's Avatar
dme makes a rear strut bar if thats what you talking about. i have one .
aciddrop i think you are talking about a harness bar??
Old Jan 25, 2009 | 07:27 PM
AcidDrop's Avatar
DME, Greddy, Ingalls, and MonsterMotorWorks make rear strut bars.
Edit: it's called a cross floor strut bar.
Old Jan 28, 2009 | 03:33 PM
Jlowe's Avatar
http://cgi.ebay.com/ebaymotors/ADJUS...Q5fAccessories
I think thats what hes talking about. I wouldn't get it, I don't really see how it would do anything but be annoying.
Old Jan 28, 2009 | 03:49 PM
senseiturtle's Avatar
Just my opinion, you may want to consider reinforcing something outside of the safety cage first. Strut tower bars, bushings, suspension components (sway, spring, shock), etc are all much more immediately noticeable and effective.
If you're at the point where you need chassis stiffening INSIDE the passenger cabin, then you're racing seriously enough to need a full welded-in roll cage.
Old Jan 28, 2009 | 08:41 PM
blackcherry07's Avatar
i agree on all but the bold....our strut towers are so close to the firewalll that it offers our stiffening....
Old Jan 29, 2009 | 01:42 PM
I've posted a thread about the dynamics of a strut tower bar, and they're much more effective than many give them credit for. Of course, on that technical discussion thread, few read it, and even fewer replied.
The gist of the argument is simply that if you consider the lateral forces imposed by a cornering car at the tire, that this force applies a torque against the 3 bolts at the top of the suspension unit, with a value which can reach 3,000+ ft-lbs during a heavy static turn. The impulse forces sustained during potholes are even greater. With this in mind, draw out a force diagram, and it's very simple to see that a FSTB will go a long way in resisting positive camber gain. I would be happy to link articles if you still don't believe me.
It's also interesting to me that people are pushing the Ingalls rear strut braces, which claim to do the same thing, but do so RIGHT ON TOP of the MASSIVE section of rear frame. See, those suspension bolts are directly incorporated into the frame... and that bar runs about 1.5 inches directly above it across the cross-section of the car.
In the front, the suspension bolts are NOT incorporated into the frame, to the same degree. It's about 4 inches from the firewall. In addition, it's arguably more important than the rear in terms of maintaining camber through the turn, since you're relying on those front tires to do ALL of the turning, and ALL of the accelerating.
I got my front strut tower bar as a last piece to my STS puzzle, just sort of as an afterthought. I immediately gained a lot of respect for it. In fact, it's managed to calm down my rear rend, which gets really loose at the end of a fast slalom... i tend to exit those semi-sideways, just from the continual loss of composure throwing it side-to-side.
Old Jan 29, 2009 | 01:49 PM
ok...well i cant ignore your proven research at all and i stand corrected....but now i ask....would it not be better to use a triangulated bar?? if what you are saying is that the strut tower is far enough from the firewall to need to be re-inforced then we should use a triangulated bar not just a cross bar...
also shoot me a link to your thread i would love to read it....i must have missed it...
Old Jan 29, 2009 | 01:51 PM
SW_08's Avatar
Old Jan 29, 2009 | 02:07 PM
Would it be? Well, perhaps, but it's hard to say. Most of the benefit of the strut bars comes from the welds between the contact plate and the tubes.... this is what resists camber addition. The secondary benefit comes from preventing compression/expansion, which helps with the frame twist. Adding a triangulated bar would only affect this "secondary" benefit... but i certainly don't see anything wrong with it.
https://www.scionlife.com/forums/viewtopic.php?t=245938
or can be searched as the only result for "rethinking strut"
I don't want to give the impression that it's the "end-all, be-all" modification... and certain manufacturers of poorly-welded, or not-even-welded models are certainly lacking any and all benefit from a suspension standpoint (bling only).... but a well-constructed unit DOES have some merit, and I don't regret it on my car.
The only mod I truly regret, is the header, which I got annoyed with and gave away. Also put me in SM... but that's another story.
Old Jan 29, 2009 | 03:42 PM
well i have a friend who is a spectacular welder so ill get with him and see if me and him can come up with some type of triangulated bar...
Old Jan 31, 2009 | 10:52 PM
highvoltage1's Avatar
Ok sensaiturtle so on installing a FSTB is it best to jack up the vehicle to install or leave on the ground, or one side at a time?
Old Feb 1, 2009 | 12:32 AM
O4COBRA's Avatar
I've always noticed a big improvement from a rear bar. But with the tC I don't see the need. The way the struts mount to the floor there is already a bar like structure there, that the upper mounts straddle.
Old Feb 1, 2009 | 12:47 AM
The instructions state to install the bar with no weight on the wheels. So, that's the way I did it. In the end, I'm not sure if it really matters or not.
Old Feb 1, 2009 | 05:49 PM
Thats what i always thought but wanted to see your opinion since you made a good write-up.
gedster314
Regional - Pacific South
Feb 19, 2021 07:51 PM
rvascion
Nov 12, 2020 03:23 AM
SloTC1
Aug 16, 2018 02:45 PM
kb1sxv
Oct 21, 2015 05:00 PM
babyfac3pn01
Oct 19, 2015 07:24 AM
