tein s-tech installation question
Old Sep 3, 2007 | 09:19 AM
sp0t's Avatar
Default tein s-tech installation question
quick question.. for the installation of the rear springs of the tein s-techs, do the foam bumper stops need to be cut? because i installed it, didn't cut it.. and my rears look high compared to the other tc's with tein s-techs on this forum.
Old Sep 3, 2007 | 10:11 AM
suvving's Avatar
I cut my foam/rubber stoppers about an inch when I installed my TRDs, so you're probably supposed to do the same for stechs.
Old Sep 3, 2007 | 03:58 PM
hawgs74's Avatar
Your supposed to cut them in half --says so right in the directions
Old Sep 3, 2007 | 08:27 PM
sp0t's Avatar
would cutting the foam bump stoppers change the height of the car at all? or its more of a comfort option?
Old Sep 3, 2007 | 09:09 PM
hawgs74's Avatar
It makes it sit lower by .5 inch or so
Old Sep 3, 2007 | 10:37 PM
jjllgg66's Avatar
Default s-techs
if you dont cut the bump stops will the car be sitting on them?....i was told not to cut them because of the car bouncing when hittin bumps and im not having any problems so far...any feed back?
Old Sep 4, 2007 | 07:21 AM
sp0t's Avatar
yeah, the shop i went to get my tein s-techs installed at didn't cut the bump stops.. but everything seems ok.. i dont bottom out, no weird noise (except the squeaking from the rear sway bar), no clunking, nothing out of the ordinary..
Old Sep 14, 2007 | 01:05 AM
BlueTC06's Avatar
Never cut your bump stops!!!
Old Sep 14, 2007 | 01:14 AM
DjEzE's Avatar
DO NOT CUT THE BUMP STOPS. yes i screamed. if u cut them ull look like ur driving a civic. we dont want that to happen do we?
Old Nov 15, 2007 | 02:17 AM
jjllgg66's Avatar
Default !
I think mine ride a lil stiffer without cutting the stops but I like it like that!
Old Nov 15, 2007 | 08:12 PM
trdsparks's Avatar
Some of the companies (Progress I know of for sure) say in the "destructions" to cut the bump stops. I have not seen the instructions for the Teins so I can't say about them.
Old Nov 15, 2007 | 10:35 PM
BlueTC06's Avatar
I stand corrected about what I said earlier, I meant you should always keep them in there, Tein H. Tech tell you to cut them down 1/2" on the fronts. Just never remove them completely
Old Nov 19, 2007 | 01:13 AM
Higgy's Avatar
Im looking at the instructions for the s-techs right here and it says you are supposed to cut 1.2 inch off the front and nothing off the rear. When I put mine on I didnt cut it. Its only been a week but I havent noticed any negative effects.
Old Nov 19, 2007 | 06:53 PM
2azfeboost's Avatar
so cutting the bumper stops lowers the car? i better do it then...
wiltonhall
Jun 23, 2025 10:09 PM
TotalChaos
13
Feb 4, 2015 10:24 PM
Beesh
Jan 9, 2015 06:30 PM
TheTripleC
Jan 4, 2015 06:46 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
