tein s techs or h techs? with 18 inch rims
Old Feb 27, 2009 | 06:09 AM
1989menace's Avatar
hope you like the h techs....i think with 18's with s techs would have looked a lot better tho
Old Feb 27, 2009 | 06:11 AM
Firefightin_tC's Avatar
Team Scionce
I'm ridin' on S-Techs with a 18" rim on 255/40/18 tires...slight rub when I run over a dip in the road, other than that...love it!
Old Feb 27, 2009 | 09:44 PM
xdejablu3x's Avatar
Originally Posted by shinjitai
S-techs. Mine rode way much better than stock IMHO.
18x9.5 38 offset. 225/40/18. NO RUB unless you gun it on speed bumps.
heres for stock wheels too.
are those Volk TE37's with the concave looK?!
Old Feb 27, 2009 | 09:50 PM
jj90011's Avatar
Depends on what your looking for i had trd springs on and i can tell you their garbage the drop was so minimal it looked stock. i have tien s techs now and i love the look but i rub on every bump. way better though than trd with my car boucing left to right.i also have 18 " rims and the tire is 235/40/18.
Old Feb 27, 2009 | 11:21 PM
BlizZard's Avatar
No, there Rota Grid, the knock-off versions...
Old Feb 28, 2009 | 01:52 AM
engifineer's Avatar
You may like the look better, but TRD is a much better setup for handling than stechs. IF you look at what many others that compete with their cars run, you will see that. Actually, the preferred setup is a tad lower than TRD with higher spring rates (And this is what I have found is needed after autoxing 2 years with the TRDs). Stechs are around 85% lower than TRDs (which, is much lower than the sweet spot on this cars geometry which is bad by itself) but have rates that are only 20% higher, which is way too soft for that much drop. This is why some have tried autoxing on them and had to deal with bouncing off the bump stops in every hard turn.
So if you just like the more extreme drop and dont mind sacrificing handling, then that is fine for what you want. But TRDs are far from stock height rise either, just not as slammed as some would like, so it depends on what you want.
Old Feb 28, 2009 | 02:04 AM
huslindan's Avatar
well engifineer what springs would you say are the best out there then? not just between s techs and h techs all the springs out there. also using the stock struts?
Old Feb 28, 2009 | 02:06 AM
zmulleni's Avatar
OhioScions
go ***** out and get basic's or super streets... since we're on the tein topic.
Old Feb 28, 2009 | 02:10 AM
huslindan's Avatar
i no i just wanted to see what he had to say goshh lol
Old Feb 28, 2009 | 02:13 AM
engifineer's Avatar
^^ yup on the ss-ps Those arent THE best, but pretty good. The SS-Ps have high rates, adjustable camber up front with the pillow ball mounts adjustable damping and of course adjustable ride height. I will be setting mine up (changing to those as soon as it warms up a bit here) at about 1.4 inches of drop, which seems to be the consensus from most on the optimal drop for our geometry.
Something from JIC would be better, but much more spendy.
If you dont want to drop $1500 or so on the coilovers (And you probably dont need to unless you really want to tune and corner balance it) then I do hear that H&R Sports are pretty nice. I dont know the rates, but they are right at the 1.4 inch drop. I think some have had good luck with progress, but they are a bit lower than optimal. However, if you really want the more extreme drop, they are probably about in the middle between way too low and the right drop. So those may be an option as well.
A number of us have collected info on the springs, rates, suspension info, etc at these links.
http://www.yoursciontc.com/forums/in...howtopic=16894
http://www.yoursciontc.com/forums/in...howtopic=26448
Old Feb 28, 2009 | 04:18 AM
jj90011's Avatar
yeah your right "engifineer" it all depends on what your looking foir. if you want looks like i did go with s techs if you want aggressive handling well i cant really point you in the right direction as i really never looked into other springs besides trd and stechs.
Old Feb 28, 2009 | 04:33 PM
engifineer's Avatar
I actually like the TRD drop much better lookswise than the stechs, but that is all personal preference so that will vary person to person of course.
Old Feb 28, 2009 | 11:37 PM
blkchrytc's Avatar
do you have to reinstall the springs if you get bigger rims/tires. cus i wanna buy the h-techs for my stockies, but im gonna buy 18s in about two months. i want like a two to three finger gap
Old Feb 28, 2009 | 11:52 PM
Ukno0003's Avatar
Originally Posted by NYNCTC
going the same route soon, let us know how you like it
Sid buy my S-Techs when I take them off my tC when I get back from school in the summer. S-techs are the way to go. Ill let you see my tC sometime (I dont think you've ever seen it in person). S-techs are the perfect drop really. And Idk why people say they slam the tC. It really doesnt. When i first got strings i was worried about going to low and i didnt want stechs for that reason. But then i saw a friend of mine with them on his tC and i had to order myself a set.
Old Feb 28, 2009 | 11:55 PM
Ukno0003's Avatar
18's are fine with stechs or Htechs. I run Stechs and i have 18's. If you want a two to three finger gap on your car then get trd's. Anything else will put u with less then that.
Old Mar 1, 2009 | 12:05 AM
blkchrytc's Avatar
but if i put h techs on my stockies then i get new wheels will i have to reinstall them again
Old Mar 1, 2009 | 12:12 AM
Crimson_Sky's Avatar
I ended up getting htechs with tokico hp struts figuring mild drop with great struts...when the struts made the car drop even more i believe...the ride quality is similar to stock, soft for the most part, but stiff when you need it to be cause of the struts...
I'm lovin the set up...
Old Mar 1, 2009 | 12:15 AM
engifineer's Avatar
Springs dont install on your wheels, so you dont have to reinstall springs when you change wheels.
Old Mar 1, 2009 | 12:18 AM
blkchrytc's Avatar
i didnt mean on my wheels, sorry, but if i decided to do a two finger gap while on stockies, then when i buy 18s will they still have a two finger gap?
Old Mar 1, 2009 | 01:38 AM
Ukno0003's Avatar
no u wont
