TRD springs conclusion
Old Jun 21, 2005 | 07:05 PM
duston831's Avatar
Default TRD springs conclusion
yea its another trd springs topic
i read alot of people who installed trd spring and whatever other brand springs, were having some problems with the passenger side being higher than the driver side. Did this happen to the majority of people? did they all settle evenly after a while or was there some other solution?
i plan on getting trd springs next week so just want to make sure everything is kewl
Old Jun 21, 2005 | 11:37 PM
Mr_Meaty's Avatar
I really dont' think it's noticable. But if you have the dealer install them, they will probably fix it for you if it doens' settle after a month or so.
Old Jun 22, 2005 | 12:00 AM
Ct_noicS's Avatar
I agree, if your worried about whether it will sit differently from side to side. The dealership "should" stand behind the TRD's if they install them. Best way for peace of mind.
Old Jun 22, 2005 | 12:56 AM
05-RS1's Avatar
does this happen just for the peoplle that install the trd lowering springs on the stock shocks? im planning on getting both the trd shocks and springs...as a matter of fact, they should be coming in by the end of this week at the earliest :-D. from wut i read, only the ppl that put them on stock shocks hav this problem..am i wrong?
Old Jun 22, 2005 | 05:51 AM
mr_lore's Avatar
The varying hieghts on the TRD springs is caused by improper installations, there is a point on the strut that the end of the spring shouldnt go past, its right before the notch in the bottom of the strut, if the spring rotates past that point, it sits very slightly lower. Just have someone who knows what theyre doing install em. I'm lucky my best friend is toyota certafied so he pointed this out to me while we installed em.
Old Jun 22, 2005 | 12:54 PM
Rivulent's Avatar
I'm pretty sure everyone knows that. It's pretty self-explanatory when you look at the spring housing. If the installer doesn't realize that, they shouldn't be working with cars .
However, I think the issue is the driver's side setting before the passenger side, because people generally drive alone. I've read other people with other springs having the same issue. This is an issue with gravitational physics, not spring integrity.
Old Jun 22, 2005 | 07:03 PM
k_splay's Avatar
What if they're both sitting in the same position? They should ride at the same height, right?
-K
Old Jun 22, 2005 | 07:40 PM
mr_lore's Avatar
I just thought I'd mention ut b/c there is atleast 10 threads about this, I figured some people just were'nt paying attention or something. My car sits level and all of the springs are rotated correctly is all i know.
Old Jun 22, 2005 | 08:15 PM
apexjr's Avatar
I installed my TRD Springs with the stock shocks, all sides sat fine since I first installed them. They didn't need to settle... *shrug*
Old Jun 29, 2005 | 06:36 PM
Marshall's Avatar
I have the TRD Struts and Springs installed; I love them! There have never been any issues with uneveness, and 90% of time with only a driver for about 5000 miles so far. Unless you are seriously obese, I am fairly confident that most of these uneveness issues are do to improper springs installs.
Old Jun 30, 2005 | 04:06 AM
wooky1976's Avatar
The reason one side sits higher or lower is that the technicians didn't read the instructions that came with the springs. I helped installed the springs and shocks with my buddy at work who is a certified technician. Trust me certified doesn't me that much because I am not and corrected him twice tonight. I have been correcting a lot of technicians within a year, isn't that sad. Here's the reason, they are usually underpaid and tired. Anyways he put the rear springs in the front and when he tried to put the front ones in the rear they were too big for the mounts.
The instructions states that the rear spring ends should be the same positionl So if the end is at 3 o'clock then the both left and right should be all at 3 o'clock. The fronts don't matter because the spring ends catch onto the mount so that it doesn't move around.
Old Jul 4, 2005 | 02:12 PM
Sparks_Scion_TRD_Parts's Avatar
Default Re: TRD springs conclusion
Read the post from Eric, it's the 3rd one down. He had the problem and it came from a simple error during the install. Hope that helps.
http://www.yoursciontc.com/forums/in...15&#entry73003
Ken
www.trdsparks.com
Old Jul 5, 2005 | 05:12 AM
playboyplaya609's Avatar
does anyone know how much the dealer would charge to install the springs???
Old Jul 5, 2005 | 06:45 AM
Krayzie_Los's Avatar
mine didn't come with instructions, but i was able to install both the TRD springs and shocks myself. car sits level though i'd like the front to be a little lower
Old Jul 5, 2005 | 05:53 PM
duston831's Avatar
one of the dealerships wanted 650 JUST to install the springs...........i laughed and hung up
Old Jul 5, 2005 | 05:59 PM
Default Install?
The Dealers really vary a lot depending on location and interest in the job. We charge $320 to $360 and that includes the 4 wheels alignment.
Ken
www.trdsparks.com
Old Jul 5, 2005 | 06:05 PM
lol wow, i was thinkin pretty cheap u know 50 to 100 bucks...lol but daaaamn...if i were to get trd springs and have some shop install it or some ppl i know would it nullify the warranty if toyota doesnt do the isntall even though they are trd?
Old Jul 5, 2005 | 06:20 PM
Default Warranty!
You won't void your warranty by putting springs on your car as long as they are made to go on your car and the install is done correctly. A Dealer must prove that the install was done incorrectly and damaged the car or that the part is defective and damaged your car. A Dealer cannot just 'say' you don't have a warranty.
Ken
Old Jul 5, 2005 | 11:52 PM
reverendericd's Avatar
here is my post from yoursciontc.com:
I figured it out............checked everything and they were in correctly......upon inspection of the struts when they are out of the car you will notice that the orientation of the left spring is different than the right (so they will fit). because of this the left strut becomes abou 1/8-1/4 inch shorter!! FIX!!!!!! (def. REAR BUT PROB FRONT TOO!!!!)..............LEAVE THE STRUTS IN THE CAR!!!!!! take the trunk apart so you can see the top of the struts (you have to take out the side walls). Once you can see the strut tops, pry the plastic cover off. NOW WITH THE CAR ON THE GROUND (not jacked up), crank the strut top nut down on the strut that is higher!!! YOU WILL BE AMAZED AT HOW FAR DOWN YOU CAN GO. This will essentially "even out" the two sides. I assume this will work on the front as well, as you can take theplastic tops out to see the screw with NO EFFORT.
I got this tip from a mechanic who worked with race cars, and he said sometimes the shorter springs + the strut orientation will result in one side being taller (or shorter). That is why there will be some thread left in the strut top screw.
Good Luck.............THIS WORKED FOR ME!
Old Jul 6, 2005 | 07:36 AM
apexjr's Avatar
Good Info!
DJ_FroZone
25
May 30, 2019 07:17 PM
danielv
Aug 26, 2015 07:14 PM
Scion0814
Scion xB 2nd-Gen Wheel & Tire
Feb 12, 2015 01:41 AM
JPuehl
Jan 10, 2015 01:01 AM
minter66
Dec 15, 2014 01:45 PM
