TRD springs install, one side higher than other
So I just finished installing my springs today. 7 hours total, ouch! (by myself and in the rain.
I took it around the block a few times and when i got back, I found the front right to be much higher than the driver side. Is this normal? If not, how do I fix it?
I followed three dif. threads on how to install perfectly, well, some trouble spots but everything is torqued correctly and in order. HELP
well, i've done them before on a 03 325i and didn't have a problem so i thought i would try it again. I read somewhere in thread that this had happened and that it settled but i couldn't find the thread again so I was hoping someone could verify them.
Plus, i think i means more when you do your own work
Mine was like that until they 'settled'. Now, the sides are so close (like millimeters off) you can't really tell. 7 hours?
Makes me glad I had Stylis install mine for me. He took about 70 mins. fighting off hunger to do mine. Well worth the $$$. You'll be happy with them (now and after they settle). Makes the tC look that much better IMO. I strongly believe Scion should make the Springs a 'Standard Option'.
please dont ever go to the dealer to get something installed! They charge way too much! they quoted me $500.
about the springs. i would give it about a week or so. It should settle out itself.
I went out this morning and tried using a "tip" i found in another thread about tightening the strut while it was installed. It was already to the torque specs but when i remeasured, i found it had dropped an 1/8 in overnight!
So they probably just need to settle...
DJ_FroZone
25
May 30, 2019 07:17 PM
kleecker
Dec 31, 2014 09:42 AM
minter66
Dec 15, 2014 01:45 PM
