TWM vs. TRD vs B&M short shifter.
Old Mar 4, 2005 | 02:23 PM
  #41
fulcrum_approach's Avatar
Originally Posted by Mr Meaty
I need to hear more opinions from people with the B&M shifter, since it lowers the shaft a half an inch and changes the pivot point.
I installed the B&M last night and really like it. The throw is shorter and the shaft is lower by about 1/2 inch. For me though, this is what I wanted cause I have the small TRD ball-type shift **** that is not weighted. The extra arm length helps with leverage. I have had C's and TRD short shifters in the past and the B&M is a very nice product.
Old Mar 4, 2005 | 03:39 PM
  #42
vikvaughn's Avatar
TWM has someone on this forum just ask him/her for the specifics on their shifter and shift ****...Here is my TWM shifter w/ shift ****
Old Mar 4, 2005 | 05:35 PM
  #43
TWM_Performance's Avatar
Originally Posted by Mediocre Generica
I can accurately say that the TWM is poorly designed because it's just a shortened shift arm, period. It is widely known that shortening the shift arm is a ghetto way to make a short shifter. It increases effort, decreases shifter height (which is, for the sane, a bad thing), and also manages to reduce throw in the process.
If you're judging the shifters by the shortest throw possible you're a moron anyways. If you wanted a super short throw, why not just hack off your stock one and have it threaded by someone with a die and thread kit? That's pretty much what the TWM shifter is doing.
I feel its necessary at this point to clear this up. The above statement is false. A great deal of research and development goes into every shifter which we design. Unlike many other companies we specialize in the design and manufacture of short shifters specifically, so we most certainly understand the concept behind them. The tC shifter, like all of the shifters we design, does reposition the pivot point as well as the overall height of the shifter. This is an issue that has been discussed in the past, please see the post below for a more detailed explanation. Note the picture which compares our shifter to the stock tC shifter, it clearly shows that the pivot point has been adjusted (as many members of this board have already pointed).
I'm always available to answer any questions that anyone has regarding our products.
Thanks,
Karel Wegert
TWM Performance
Originally Posted by TWM Performance
Originally Posted by i64X
I wont be buying that at all... it's a total waste of money for something it doesn't do. It dosen't shorten the shifts, it just feels like it does cuz they made the top of the shifter shorter. A "short shifter" doesn't mean that the stick you see is shorter necessarily, it means that your shift throws are shorter. This is accomplished by raising the pivot point on the shifter (the ball) like this:
What TMW did on that shifter could easily be accomplished by taking your stock shfiter out and hack-sawing about 2" from the top of it and then installing some kind of universal set-screw type shift ****. Check this out:
They didn't raise the pivot point at all... it's exactly the same length as the stock one. The whole idea behind raising the pivot point is that it takes less movement on top of that point to make the bottom of the lever move more.
TMWs shifter isn't a "short shfiter" at all... it's just a "shortened" shifter and provides no real performance upgrade. It's simply for looks... and it costs way more than it should.
Your concept is correct but in this case the picture you used to illustrate your point is slightly misleading. First, the shifters are at an odd angle which creates the illusion that they are the same length below the pivot ball when in fact they are not. Also, the stock shifter still has the plastic cup installed on the lower ball, which makes it appear longer than it actually is because it ends lower than the ball inside it does. I do, however, see how you could make this assumption based on the picture you saw as it does create a strange illusion.
Our tC shifter is actually roughly .5" longer below the pivot ball, the maximum amount of added length possible due to clearance issues with the shift assembly.
I've attached a picture we took quickly this morning that shows a stock tC shifter next to our part from an overhead perspective, as you can see the difference in length below the pivot ball is much more apparant from this angle.
I hope this clears things up a little bit, feel free to contact me directly if anyone ever has any questions about our products.
Thanks,
Karel Wegert
TWM Performance
Old Mar 4, 2005 | 05:56 PM
  #44
RA31925's Avatar
like i said. the pivot point has been changed
Old Mar 4, 2005 | 06:57 PM
  #45
aarontrini85's Avatar
i said it to i said it to now if only i could order one damn i need to pay off my credit card
Old Mar 4, 2005 | 07:35 PM
  #46
Mediocre_Generica's Avatar
Thanks,
Karel Wegert
TWM Performance
Interesting, but if you measure the lengths shown in the picture above, the length below the pivot ball is exactly the same. The shifteres are oriented in same way, so if there's any distortion due to weird angles, it should be present on both of them.
I can see that it's obvious from the pictures that you posted, but why would it be any different for anyone else? Why the discrepency?
Old Mar 4, 2005 | 08:53 PM
  #47
Mr_Meaty's Avatar
Awsome Karel! Thank you so much for the info! I was going to contact you directly, but you did not leave your contact information, so I'll just ask you a question here:
I am planning on getting the TWM shifter and putting the Sparco Bio shift **** on it. http://www.sparcousa.com/ptuning_knobs.asp?id=306 I'm hoping it's a little taller then the regular ****. How do you think this will effect the throw of your short shifter?
Old Mar 4, 2005 | 09:05 PM
  #48
jmiller20874's Avatar
Thanks,
Karel Wegert
TWM Performance
Dude, lay off the paint chips! What more proof do you need? Why are you arguing with the manufactuer and eveyone else for that matter?
Old Mar 4, 2005 | 09:25 PM
  #49
I'm skeptical! There are two clearly different pictures!
Old Mar 4, 2005 | 11:23 PM
  #50
RA31925's Avatar
buy one and if its not what you think or up to your standards. return it. you must have been lied to alot when you were a child . j/k and seriously most peps here are stating that it is changed and yet you still do not believe it. so sad sorry.
Old Mar 5, 2005 | 12:11 AM
  #51
motozen's Avatar
Originally Posted by KYBoy
twm is not cheap it all, it is a very nice product and anyone that has one will say the same thing. I have not herd one bad thing about twm. it offers the shortest throw right now. as far as the height it is a preference thing and you already said you wanted it lower. you can get the twm for about 10.00 more than the b&m and lower you shifter height more and reduce the throw as well.
true eh. not only is it a great product eh, but the fellas in canada are a pretty cool bunch of mooses eh.
Go TWM or go nowhere. Gee that's a pretty good slogan! TWM you can pay me now!
Old Mar 7, 2005 | 01:21 PM
  #52
Sorry about that, you can reach me any time at kwegert@twmperformance.com or 1-888-569-8963.
Using a taller shift ****, like the sparco part, won't really change the throw of our shifter a great deal. If you sat down and did the calculations it may add a couple of percent but it won't really be noticeable. The majority of throw reduction on of part comes from the new placement for the pivot point.
Hope that helps...
Karel
TWM
Old Mar 7, 2005 | 01:49 PM
  #53
Mr_Meaty's Avatar
Awsome! Perfect! I'm sold!
Old Mar 7, 2005 | 07:01 PM
  #54
motozen's Avatar
Hope that helps...
Karel
TWM
What is the thread size for our shifter? TIA
Old Mar 8, 2005 | 01:40 PM
  #55
rcruz2525's Avatar
Karel, thanks for the clarification of the TWM. I will be getting one soon.
Nice job…
Old Mar 8, 2005 | 04:32 PM
  #56
CHICO's Avatar
I just installed a Perrin Short shifter on a TC, is fully adjustable, is a little bit shorter looking than stock, but the throws are some of the shortest I have evel felt on a car, also the feel is VERY solid. I need to find a TC with the TWM so I can compare the two.
Old Mar 8, 2005 | 04:42 PM
  #57
where did you find a perrin for a tc? the only one i see on there site looks like its for an xb please let me know where you found it they seem realy cool becouse you can select the throw
Old Mar 8, 2005 | 05:15 PM
  #58
CHICO's Avatar
Perrin send me a prototype to test out, wich just happens to be the same shifter for the Xa/Xb, I went over to vividracing to use their shop for the install, and I know they have some XA/XB shifters wich are the same as the TC, might want to give them a call.
Old Mar 8, 2005 | 05:21 PM
  #59
then my shifter will me tall as hell i want a short stance from my shifter also or atleast the factory hight i dont want it any taller
Old Mar 8, 2005 | 05:39 PM
  #60
IndigoDreams's Avatar
I dont care what all the non believers say, I personally have the TWM, a friend of mine has the TRD, and another has B&M and after driving them all we all came to the conclusion that the TWM was the shortest throw. After driving a while they really got used to my low stance shifter and wished they bought it instead of the ones they have. The shifters in our tC's look rediculous at how TALL they are and should have been alot shorter from the factory
