TWM vs. TRD vs B&M short shifter.
Originally Posted by lootyman
^ yeah, um you're obviously very rad mr NOS.
maybe mr meaty likes to have beverages in his car.
Well, I do want the shaft lower then stock, but the TWM does look REALLY short. Does anyone know the height difference between the TWM vs. B&M vs. TRD?
So far, I'm still leaning towards the B&M. Does anyone even have that?
Well, I read the description of the B&M shifter at trdsparks.com and it said it only drops the stick a half an inch. And I saw the pics on t6c9's car, and it looks pretty much stock height. Still too tall. Maybe I'll just get the TWM shifter and get a taller Sparco shift ****?
Originally Posted by TheKnown
is the short shifter all that great of a mod? im not bashing im asking.... ive never driven a car with one installed or known anyone with one.
Originally Posted by SSMtC05
The TWM does not do it the cheap way, i happen to have it and when compared to the stock shifter the pivot point is changed about 1/2 to 3/4 of an inch. Also it reduces the **** height by about 2.5 inches. So it does both, change pivot point and reduce **** height. The TRD changes pivot point, but also cost more because it comes with the shift ****, an extra 57 dollar value( price taken from mcgeorge) and it also is installed in the basket already which is alot easier to install. Whereas the TWM has you remove all sorts of parts to drop the new lever in.
Jay
Jay
The TRD costs more becaues it comes with the entire plastic housing as well as the **** and shift arm, and because actual research and development went into it instead of TWM, who rushed out a poorly designed product to make money off suckers eager for an easy mod.
Scion Corps
DeepSouth Scions
Jay
Jay
TRD cost more b/c of mark up by toyota not b/c of the amount of research that went in to it.
but lets just say they did do more research twm is still a shorter throw so you tell me which one is better?
performance wise the twm.
TWM made the shifter arm shorter AND moved the pivot point reducing the length of the throws. It is harder to install than TRD, but it's not an inferior shifter. If you are willing to get your hands dirty - save $150 and get a TWM...
I just installed the TWM and i love it....The shifting is alot quicker, and its also a little tighter to shift, which i didnt like at first but now i love, cause it feels like the gears click into place...feels a little more racey....
ps...aarontrini85 How Did U go About fixing Your shift boot...mine looks all scrunched up
[/img]
[/img]
If so, here is a little word-less DIY that I put together for people who asked how to fix the shift boot: http://zoltiz.com/cars/tc/bootdiy/
Originally Posted by KYBoy
now its poorly designed
I can accurately say that the TWM is poorly designed because it's just a shortened shift arm, period. It is widely known that shortening the shift arm is a ghetto way to make a short shifter. It increases effort, decreases shifter height (which is, for the sane, a bad thing), and also manages to reduce throw in the process.
If you're judging the shifters by the shortest throw possible you're a moron anyways. If you wanted a super short throw, why not just hack off your stock one and have it threaded by someone with a die and thread kit? That's pretty much what the TWM shifter is doing.
The TRD shifter does everything right: reduces throw, keeps the stock shifter height, and changes the attachment to the linkage for good shifter feel as opposed to lopping off the top of the stock design.
I have the TWM w/ the shift **** and I LOVE IT.....if your into a factory feeling short shifter get the TWM...it is similar to the S2K and the Miata...the pivot point is changed and the w/ the shift **** it helps the shifter slide alot easier into gear. Also, it doesn't get hot at all, the shift **** is all steel and coated so it doesn't rust or anything....I think it's the best short shifter kit on the market for the tc....IMO
TWM posted a pic in a earlier thread. and there is a difference in the pivot point. 1 the height is dropped lower. and also the pivot point is reduced. IMO twm made a good shifter and so did trd. if you have the money go TRD, and if you like the stock height with a short throw. but if you want the short height and short throw go TWM. most people here think that TWM is basically a stock shifter that has been chopped.
not true. installation might be harder than TRD, but its at half the cost. so i hope that helps some.
yeah, I find it hard to believe that throws can be reduced by 35% just by dropping the ****. Plus, the descripton on TWMs site says it reduces throws AND drops the **** height. I'm liking it.
