Upgrading sway bar endlinks
Make them. Couple of heims (regular and reverse), and internally threaded hex for the body of the links. You could source all the parts from a circle track supplier, or any good hardware jpint, like McMaster. They'll look like this, only well, smaller.
Dont worry R2d2. I am here to help you out. Here is the name you have been waiting for. The company is Ingalls. We are making new rear strut bra that has the braces needed to work(not just a bar), front strut bar, engine torque dampner, 4point brace for front subframe, front and rear sways WITH NEW LINKS and Springs with a level even drop. PM ME FOR MORE INFO
I cant just yet. i will post a link for anyone to see what kind of ideas this company has instore for the whole sport compact scene not just Scion
http://www.ingallseng.com/
progress comes with their own endlinks for their sway bars but its not any beefier. just adjustable. but should provide alot more strength than the stock rear ones. those are just flimsy as hell
My driver side enlink just broke on my car.
Is there anyway I can purchase new sturdier endlinks rather than going to the dealer?
Went to the dealer today and they wanted to charge me $72 for the left side endlink.
I'm down to purchase an aftermarket endlink from someone if possible
Why are you buying a warrrantied part?
Where did it break?
What were you doing when it broke?
It's a 10mm solid mild steel rod. That's pretty strong for both compression and tension (the two modes in which it works).
Where did it break?
R2D2
I am running the Hotchkis Sway Set Front and Rear
lo_bux_racer
I haven't bought the endlink yet. I just went to the dealership to see how much it would run me. The nut that was screwed on isn't there anymore and I've tried to find the right nut for it and I can't seem to find the right size. The bottom part of the endlink is broken because all the grease is goo-ing out. So I figured it was time to replace both endlinks with aftermarket products if anyone makes some.
Do you know of anyone who makes any aftermarket endlinks?
Which swaybars are u runnin?
lo_bux_racer
Where did it break?
Where did it break?
