wheel lug pattern?
depends on the width of the wheel too. but generally speaking, the lower the offset, the more the wheel sticks out.
most 5x100 19inch axis wheels are 8 or 8.5 inches wide. compared to the 7 inch wide 45 mm offset stock wheel.
1 inch = 24 mm. so if your wheel is 1 inch wider, then it sticks out 12mm on each side. but since the wheel is 35mm offset, the outside sticks out 22 (12+10mm) while the inside is only 2mm wider (12-10mm), compared to a stock wheel. if your wheel is 8.5 inches wide, then add 6mm to each side.
JM Auto Racing
Dec 19, 2014 06:36 PM
