Will 18x8.5 rub?
Old Oct 28, 2005 | 01:43 PM
psrest2's Avatar
Default Will 18x8.5 rub?
Need some help! I just bought a 2005 TC and its been lowered 2 inches.....I am wanting to put a set of stern st-2 chrome wheels on there. The setup would be 18x8.5 all around and the wheel has a 38 offset......anyone know if this will cause the wheels to rub? If so, what would be a good setup to go with?
Old Oct 28, 2005 | 02:54 PM
HKSpeed's Avatar
8.5 & et38. that setup sticks out 25mm over stock. thats very close to rubbing, but i think you'll be fine as long as you: dont add weight in the rear, dont corner hard, avoid bumps, and get a narrow tire (215/35 or 215/40)
Old Oct 28, 2005 | 02:59 PM
Da_Mac's Avatar
Here are a few threads to help you out with that question just do a search you'll find more
https://www.scionlife.com/forums/vie...+stech+springs
https://www.scionlife.com/forums/vie...ht=stechs+rims
Good Luck...
Old Oct 29, 2005 | 04:01 PM
Joe_Dezod's Avatar
It will most likely rub. I have a 1.4" drop with H&Rs and 18x8 HP Evo wheels with a 38MM offset. I rub under extreme cornering and a quick/sudden dip. Using 225/35/18.
Old Oct 29, 2005 | 04:08 PM
datrickster24's Avatar
Im on 18x8.5 Axis Hiro's +35mm offset. with 225/40/18 tires on tein s-tech drop. I rub a decent amount too .. sadly
Old Oct 29, 2005 | 06:28 PM
lo_bux_racer's Avatar
Yes it will rub. You need a +48 offset to clear with the optimum sized tire 245/35/18. I have 17 x 8.5 with 245/40/17 and a +48 offset. It does not rub ever.
I still have no idea why you guys like 225s. One drive on 245s and you'll never go back. It really is a 3000+ lb car as soon as the driver sits in it, and it needs rubber under it to get grip.
Old Oct 30, 2005 | 05:29 AM
Kilo6_one's Avatar
Default Re: Will 18x8.5 rub?
POST PICS, those are some awesome wheels, they are the only chrome wheels i would ever buy
Old Nov 1, 2005 | 01:29 AM
-Keith-'s Avatar
im on 225/40/18 with 18x8.5 with a 35 offset no rubbing here
Oh and im lowered like 2+ inches
Old Nov 2, 2005 | 11:31 AM
boostedscion's Avatar
thanks for the links those searches helped
eujin
Feb 23, 2016 01:18 AM
Rob54Monty
Jan 20, 2016 01:41 PM
terrye
Sep 26, 2015 12:24 AM
Andreas24
Sep 15, 2015 02:10 PM
Sciontuner
Mar 16, 2004 07:19 AM
