Yet another Brake Q...
Old Mar 7, 2006 | 11:02 PM
Crippie's Avatar
1UP Crew
Default Yet another Brake Q...
Been looking for a 4 piston caliper upgrade but have only found:
http://www.sportcompactonly.com/prod...1164&c=101&l=2
Are Rotoras any good? (noob) and are there any other brands making aftermarket Calipers for the tC?
Old Mar 8, 2006 | 12:02 AM
Neothin's Avatar
check out stoptech
Old Mar 8, 2006 | 12:34 AM
The_Instigator's Avatar
StopTech
Stiffest calipers on the market with some of the best flowing rotors out there. Also, the kits are track tested to ensure ideal brake balance which is the only way to effectively reduce stopping distances. More info here: http://www.zeckhausen.com/testing_brakes.htm As of now, we are the only comapny who does this testing and can guarantee that the car will match or beat stock performance. In many cases our competitors will perform worse than stock as seen in the recent Acura RSX Challenge: http://www.stoptech.com/company_info...hallenge.shtml
We are also Toyota's choice for the brake upgrades used on the Long Beach Grand Prix Celebrity race tC's: http://www.toyota.com/motorsports/ne.../10-06-01.html
Old Mar 8, 2006 | 02:36 AM
Crippie's Avatar
1UP Crew
Thanks for the help.
Hey Instigator, what are you rolling on? 17s? 18s? Did you have to use a spacer?
Old Mar 8, 2006 | 03:23 AM
Those are the stock 17s with a 5mm spacer and it is very very close. I would recommend upping the spacer to something like the 15mm H&R option which is hubcentric. The 5mm spacer is not hubcentric and the wheel register is lost which causes some vibrations at highway speeds.
Old Mar 8, 2006 | 03:33 AM
Crippie's Avatar
1UP Crew
I've also been probing around at some aftermarket wheels, do you think a bigger wheel could avoid getting a spacer all together? say 18s?
Old Mar 8, 2006 | 07:37 AM
hahaitzskippy's Avatar
wilwood, stop tech,
both are 4 piston
rotora (6piston)
Old Mar 8, 2006 | 08:35 AM
SquallLHeart's Avatar
man... those brakes look so friggen HOT! i want them!
Old Mar 8, 2006 | 01:57 PM
Neothin's Avatar
but they cost hundreds
Old Mar 8, 2006 | 02:03 PM
kungpaosamuraiii's Avatar
Thousands. 1.6 thousand.
Old Mar 8, 2006 | 03:31 PM
The stock wheels have suprisingly good clearance, and many aftermarket wheels will fit with no spacer. To ensure that the wheels you choose will fit, we have a wheel fitment template avaialble for download here: http://www.stoptech.com/tech_info/ch...55-2430-02.pdf
Instructions on how to use the tmplate are here: http://www.stoptech.com/tech_info/wheel_fitment.shtml
Many times, the manufacturers or retailers can use out templates to check clearance for you before the wheels are purchased.
gqdabien
Oct 8, 2015 05:36 PM
Klashan
Sep 24, 2015 12:39 PM
DannyBoy65
Sep 21, 2015 06:23 PM
axB
Sep 18, 2015 06:11 AM
Subaru86
Scion FR-S Aero & Exterior
Sep 14, 2015 12:39 PM
