18x9.5 et25.....
Location: Torrance, CA/ North Hollyhood, CA/ Outer Space
i have 18x9.5et27 on the rear...you should be with with some 225/40/18's couple degrees of negative camber, you will also need to cut off some of the parts that connect the rear bumper
My rears are 19x9.5 et 25..I rolled my fenders and beat the crap out my rear bumper lip metal part and removed the bolt. Tires are 225/35/19 camber at -2ish degree..my fender hits my rim on bumps and dips.
wow i didnt know all that needs to be done... well since i want the look ill have to.... so even with 18x8.5 et30 you were still rubbin bad chrischoi???
^^would that size be easier to work with?
ok so i am mos def gna get that wheel size (18x9.5 et 25) and might go with a 225/35 or 225/40, not sure yet but one question for those who got the VRD fogs... if i take out the front fender liners, how/what can i do to protect the fogs from getting filled up with water?????
my passenger side fender liner tore off on the freeway a couple months back and since then my passengerside fog has been getting filled up with water everytime it rains! what could i do to avoid that from happening again?
SubrinaIsMyCar
03-08-2015 07:53 AM
Wheeldude.com
03-25-2013 12:36 AM
