going from 17" to 18" wheels, how much does the tC
if you get the proper tires to fit the new 18s, it won't make noticeable difference in height. if you are going from stock 17s (215/45/17) then you would want to get 225/40/18 tires for the new 18s to keep the same overall diameter of the wheel. i personally would get 235/35/18 as its even closer to the stock tire size so your speedo and overall diameter wont be so far off as the 225/40/18s. however make sure you can fit them without rubbing, 235's required at least an 8 inch wide rim.
http://www.discounttiredirect.com/di...foTireMath.jsp
evolving_machine
Oct 21, 2023 01:16 PM
kleecker
Scion xB 2nd-Gen Wheel & Tire
May 22, 2016 06:10 AM
