Hotchkis 17x8 35mm rub issues?
Old Jul 20, 2007 | 05:12 PM
HiroProtagonist's Avatar
Default Hotchkis 17x8 35mm rub issues?
I'm looking to pick up a set of 5zigen fn01r-c's from edgeracing. I was wondering if 17x8 35mm offset with 215/45/17's will rub on a hotchkis drop? I know questions like these get asked every 4 seconds but I searched and could not find any definitive answer.
Old Jul 20, 2007 | 08:44 PM
Amoxaphobic's Avatar
Yeah, you should be good. That's almost (if not exactly) stock size and stock is good on the hotchkis springs.
Old Jul 20, 2007 | 08:54 PM
shadow12one's Avatar
You wont have any rubbing issues
Old Jul 20, 2007 | 08:59 PM
equinox2355's Avatar
I was wondering this myself, and IIRC the stock size is 17x7 35MM
either way good to know I can get the wheels I want and not rub with my hotchkis springs!
Old Jul 20, 2007 | 09:23 PM
Cabana's Avatar
stock is 45mm not 35
Old Jul 20, 2007 | 09:53 PM
tC9o9's Avatar
why get 8" rims if you are going to use 215's?
go with a 225 or a 235 so you can use the extra width.
but no, you shouldnt rub to answer the original question.
Old Jul 21, 2007 | 12:42 AM
^^ Yeah, I was going to suggest that to. If you are going to get 8's then you should def go with a wider tire. 225's would be good.
Old Jul 21, 2007 | 12:45 AM
zoltiz's Avatar
N.G.S.O.
I happily ran 245s on a 17x8 with 48 offset. 245/40/17 is a perfect size for the tC, too.
And when will the people realize that drop has nothing to do with rubbing. Offset and wheel/tire width are the only factors.
Now that this is taken care of. 17x8 with 35 offset is pushing it, even with 215s. It will be pretty close in the back, but might work out. Front - under full compression in a turn you can slice the tire. And you don't want this to happen with a fully compressed strut and wheel turned all the way.
http://blacktc.com/2years/2y08.jpg - that's what it looked like with 5mm spacers in the back, nothing on the front.
Old Jul 21, 2007 | 07:17 AM
tC9o9's Avatar
your right when you say wheel size and offset play the only factor when considering if you are going to rub or not, but lowering your car increases the chances.
Old Jul 21, 2007 | 07:32 AM
2fast4you's Avatar
Team ScionTific
17x8 +35 works just fine with 225/45/17, even when cornering aggressively.
Old Jul 21, 2007 | 03:49 PM
Even if lowered 2" by the Hotchkis springs? If so, sweet!
Old Jul 21, 2007 | 05:34 PM
Ok on second thought I think Im going to go with 17x8 48mm offset with either 235/45/17's or 245/40/17's I shouldnt rub at all with those should I and which do you reccamend?
Old Jul 21, 2007 | 08:35 PM
Cabana's Avatar
235/45 is the wrong sidewall, you need 235/40
Old Jul 21, 2007 | 10:03 PM
tC9o9's Avatar
a 245 can fit a 8" wheel, but i think it would be better put on a 8.5"
Old Aug 9, 2007 | 12:58 AM
deflaytedwayz1's Avatar
how does lowering your car not factor into rubbing? i don't think he said rubbing on the fender lip..i believe you can still rub on the inner fender well with the wrong size tire and too much of a drop..
carid
Feb 12, 2015 11:54 AM
TheTripleC
Jan 4, 2015 06:46 PM
OOHC
9
Nov 18, 2003 03:41 PM
smilygo
Oct 1, 2003 07:03 AM
