Hub Centric Rings (Solved!)
Where is the best places to buy these? I googled some and i didnt see the size i needed.
I had the tires balanced twice and still the wheels wobble over 60mph, so i checked and needed these things.
When i google my wheel brand, lenso, the wheels i have dont show up so im not sure what size i need.
I measured the inside part where the ring is suppose to go and it measures ~83-85mm. So im guessing i need something that has a 54.1mm inner and 83-85mm outer?
Help would be appreciated.
Are you saying the center bore on your wheels is 83-85mm? Most aftermarket wheels are 73mm. You need to measure the centerbore correctly which i suspect is 73mm.
if it is 73mm you can get them here..
http://cgi.ebay.com/ebaymotors/HUB-C...item5191919957
Subaru86
Scion FR-S ICE & Interior
09-10-2015 08:11 AM
