My new rims rollin on 245/40/r18
Old Sep 19, 2007 | 06:52 PM
Silverstreak-tC's Avatar
does offset mean how deep a lip is on the wheel and how far off where the bolts bolt up to the hub and if it bolts up too far towards the outside the wheel will hit the shock right???? just a guess
Old Sep 19, 2007 | 06:54 PM
scion_jon's Avatar
how tucked or pushed out the wheel is.
im running a 35 offset, that means im pretty close to beig lined up with the body line. stock tc wheels have a 45 offset which are much more tucked than mine
Old Sep 19, 2007 | 06:56 PM
TheQuietThings's Avatar
Originally Posted by Silverstreak-tC
im a lil new wit wheels scion jon offset means ???
check this out dude, its a pretty clear explanation
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old Sep 19, 2007 | 06:57 PM
icic thanks man (scion jon) i think if i keep these ill run the tire size you gave me earlier the 225/40/r18.
Old Sep 19, 2007 | 06:59 PM
Thanks (thequietthings) ill look into that.
Old Sep 19, 2007 | 07:00 PM
scion_jon's Avatar
cool, do you know the specd on your wheels?
here is a diagram showing a negative and positive offset
http://rds.yahoo.com/_ylt=A9G_RtrHcf...520diagram.jpg
Old Sep 19, 2007 | 07:03 PM
last nite i tried to look for it on the back of the wheels for the offset and the dimensions like its suppose to but it only showed me the bolt pattern. So i dont really know the spec's for it.
Old Sep 19, 2007 | 07:08 PM
scion_jon's Avatar
hmm thats wierd should have a number on there like
35
40
45
look for something like that
Old Sep 19, 2007 | 07:09 PM
Ace83's Avatar
Ronin Scion
Those wheels are nice man, just put the tire spec right. It has good lip, match your car's color and you're not yet lowered right so you wouldnt have issues with rubbing. If you know the name of those rims and where you get them it should help you get the specs
Old Sep 19, 2007 | 09:01 PM
hehe they are kinda a no name brand but ill check it out ill check the name on the cap of the wheel.
Old Sep 19, 2007 | 09:26 PM
man i might get the tein s tech's too i bet they're gonna rub like hell.
Old Sep 20, 2007 | 01:00 AM
ndnbolla's Avatar
I can pretty much guarantee rubbing...
I run 235/40/18 with 35mm offset wheel, rub on all 4s with a full house and H-Techs.
Im thinking about changing my tire size too, not sure which size to go to completely get rid of rubbing.
Old Sep 20, 2007 | 08:27 PM
Well my car isnt lowered so i dont have to worry bout rubbing cuz right now i have them on and no rubbing wutsoever but when i do lower im pretty sure it will.
Old Sep 20, 2007 | 09:21 PM
ooo i just found my rims are panther's EMR 429 the offset is either +35 or +45
Old Sep 20, 2007 | 09:41 PM
scion_jon's Avatar
cool
Old Sep 20, 2007 | 09:53 PM
tC4italy's Avatar
I got 18x8 with 235/40/18 and I'm having no problems, I wanted wider tires than a 225
Old Sep 20, 2007 | 09:57 PM
lets say i do decided to lower it will definitely rub huh????
Old Sep 20, 2007 | 10:02 PM
WendysOrBust's Avatar
:double post on accident:
bugh, don't listen to these guys telling you to go with a 225, stick with your 245's, IF you do decide to go lower and begin rubbing add 10mm spacers all around and roll your fenders. Your car would look insanely good after that.
Old Sep 20, 2007 | 10:03 PM
tC4italy's Avatar
again depends on yr rim sizes, tire sizes, offset and drop
