MY NEW WHEELS! on there way. I NEED INPUT
i ordered the speed star d5r 2 pc wheels in gold. the thing is i took a chance with this but i dont care i wanna make this work ive seen less on the offset used in the rear with a wide tire. I ORDERED THEM IN 18X8 IN THE FRONT 37MM OFFSET AND REAR 18X9 32MM OFFSET. will this work or am i going to have major problems? i will be using 225/40 front and 235/40 rear dropped on h-tech springs. please tell me this will work.... that i might just have to roll the fenders. thanks for any helpful responses from you tc wheel gurus!
where did you order the wheels from? tirerack? how much? i heard theyre on clearance everywhere.
the fronts will fit just fine.
i have 18x9 et24 on 225/40 in the rear and I had to roll the fenders. you rear will stick out 8mm less than mine, but your tire is 10mm wider. I'm dropped 2.5 inches. i'm not familiar with a h-tech drop, so you may avoid rubbing with that drop.
i guess you wont know for sure until you put the wheels on.
i wouldnt worry about it.
the rear is slightly flared out from fender rolling
fur_pig
Mar 20, 2020 04:28 PM
gettoastedinthetoaster
Scion xB 2nd-Gen Wheel & Tire
Dec 29, 2014 11:39 PM
