Need tC tire!!!
Old Mar 28, 2006 | 02:36 PM
FMtC9's Avatar
Default Need tC tire!!!
I got a gash on the sidewall and need to replace ONE tire.
Everywhere I go (Discount/NTB) is trying to say that I would need to replace all the tires beause the treds would be different otherwise...
Thanks guys!
P.S. The spare tire on the tC is horrific
Old Mar 28, 2006 | 02:45 PM
ack154's Avatar
I don't know about replacing ALL of the tires. But you could get away with replacing two and it would be just fine. He's kind of right about the tread being different, but not for all 4. You'd want to replace either both front or both rear.
Old Mar 28, 2006 | 02:57 PM
elemeno's Avatar
get 2 new ones and put them in front. Always keep the good ones in front since its a front wheel drive. Could you post how much they are since I'll be lookin for new tires really soon too.
Old Mar 28, 2006 | 03:02 PM
TrafficinLA's Avatar
Keep the good ones in the back. Not front.
Old Mar 28, 2006 | 03:13 PM
ack154's Avatar
If you have the Potenzas and you want to replace those, you're looking at $160+ per tire. Search around Wheel & Tire forum and you'll see a lot of other recommendations that are MUCH cheaper.
Old Mar 28, 2006 | 08:15 PM
elemeno's Avatar
Why would that be? I'm no expert but common sense tells me you want the most traction where your powers coming from. Anyone else wanna weigh in
Old Mar 28, 2006 | 08:22 PM
jbae1221's Avatar
i use to work at a tire place and you put the good one on the back they say.. i think it was because most of the weight is on the front so less traction is needed... or something like that.. you need to keep from fishtailing... I couldn't tell you 100% but that is what the big corp told me..
just replace 2.. you will be the best judge of that... how many miles... were they driven hard... they are z rated tires so they should last about 20-30k miles if well taken care of. in the gash.. do you see the wires.. if not i wouldn't replace it.. if you do.. then replace it... if all 4 are down to the traction bar.. then replace all four...
Old Mar 28, 2006 | 08:49 PM
krdshrk's Avatar
Check your PM.
Old Mar 28, 2006 | 08:57 PM
ScionBandit's Avatar
sIcKsCiOnS
DelMarVa
Scion Tuners
??? unless the tC is RWD and im not aware of that, why would you do that???
not calling u crazy, just wondering your thought on that.....maybe im missing something
if they said you need all new tires, they either dont have the tire you need or your tread is worn PRETTY bad
Old Mar 28, 2006 | 09:29 PM
Nick06tC's Avatar
If you plan on buying stock potenzas, I will sell you two stock ones with 400 miles on them. Since your gonna end up spending $300 anyhow, I will save you $100 and sell for $200 plus shipping.
Old Mar 28, 2006 | 09:33 PM
jbae1221's Avatar
this is why you put them on the back instead of the front.. because of fishtailing..
http://www.discounttire.com/dtcs/infoTiresRear.dos;jsessionid=Gp06yT61HktV2XzvHf76Bgb73K1cGnNLVJ2vp9tVlh9L1xKkk59Q!272793523!211476351
Old Mar 28, 2006 | 09:38 PM
sIcKsCiOnS
DelMarVa
Scion Tuners
wow, i guess my shop foremans 40+ years in auto experience has been wrong......
still dont rec. to put good tires in the rear
but different strokes for different folks
Old Mar 28, 2006 | 09:40 PM
jbae1221's Avatar
^^^ you want to keep all four good.. if the front blow out then you're screwed.. but for the most part. if the back don't get traction then you fishtail...
Old Mar 28, 2006 | 09:43 PM
sIcKsCiOnS
DelMarVa
Scion Tuners
i kno u want all 4 to be good, you wont fishtail all the time...only under certain conditions, does not happen to any customers cars ive put good tires up front on
i will however pass that on to the techs..see if they change their ways
Old Mar 28, 2006 | 10:32 PM
YokohamaNate's Avatar
It depends on the tread depth of the other 3 tires. If the other 3 tires are in pretty good shape, then you should be fine. If they are worn down too much, then you would need to replace all 4. Do you know what the tread depths are of the other 3 tires??
Old Mar 29, 2006 | 03:28 AM
JustAtC's Avatar
i have a pair of oem potenza tires and i will let them go for the price of one $170, you pay shipping.
Old Mar 29, 2006 | 03:40 AM
elemeno's Avatar
I know u wanna keep all of em kinda close. But I'm still leanin towards puttin my good tires on the front. U sound like u have more experience then me though so I'm not tryin 2 start a war here but lets look at this scenario.....If u have a pair of bald tires and a set of new tires, which would u put up front where the power is? Ok so if u put the new 1's on front in that scenario then why not every scenario. The front 1's r the ones to hit water first (would'nt u wanna steer somewhat while hydroplanning treads=better steering and traction) I still wanna here from some more folks on this topic
Old Mar 29, 2006 | 09:28 AM
Nick06tC's Avatar
elemeno I think you are on the right track, if the front tires are the ones hydroplanning and slidding, you cant steer out of it. if the backs are skidding atleast you have a chance to save it.
This is one of my first front wheel drive cars in years, but tell me the last time anyone was driving a front wheel drive car and skidded during normal driving? It doesnt happen OFTEN. SO i think the good tires should go where the steering and power is.
Old Mar 29, 2006 | 04:05 PM
jbae1221's Avatar
I can understand where ya'll are coming from... I'm not saying if the tires are bald then put the new ones on the back.. I'm saying if the tread is low, BUT not to the tread bar then put the new ones on the back. Reason being is because the front has more weight so less tread is needed to make better traction unlike the back where there is less weight so more tread is needed to make traction.
Plus, most drivers, whether the front hydroplan or the rear hydroplan, they will not be able to control their car.
and technically, if the fronts are hydroplanning then you do have a chance to steer out of it because you can change direction and speed, unlike the back where you can't.
Old Mar 29, 2006 | 08:29 PM
elemeno's Avatar
I guess we'll all have 2 agree 2 disagree But I think we all agree that all your tires should be prettty close to the same tread depth. I think we went off the intended topic here which was pretty much my bad.
