New Rims to complete stance build please help
Old Jan 30, 2012 | 01:30 AM
rkuemmer's Avatar
Default New Rims to complete stance build please help
Hey guys i am just starting a new post got tired of looking around and not completely figuring out this offset for my car. I am just about to order B+G RS1 Coilovers for my car if you would throu your opinion about them that would be great. What i am looking for is wheels that give that a__ aggressive stance to it. I am a offset and give it a good amount of camber but be able to keep as my daily driver. Thanks guys any help would be great
Old Jan 30, 2012 | 01:39 AM
Jon's Avatar
Jon
Moderator
Moderator
There's no perfect offset or wheel for this. Too many factors go into it. We have plenty of threads about wheel fitment already, showing various ways of going about it.
Old Jan 30, 2012 | 02:41 AM
rkuemmer's Avatar
i know just the thing is i am tired of looking around to find and not sure what would great and fit without rubing anything if i drop the car about 3in and have an aggressive wheels and mean camber
Old Jan 30, 2012 | 03:01 AM
GUNNIST14's Avatar
-Trial and error my friend.
-If you don't want any contact or little rubbing go with 17x8.25+35 or 17x8.5+35.
-The great fit part is your call man. It's your car and don't buy or do things to suite other people do it because you like it.
-If you go with a 3inch drop get a rear camber kit atleast the factory camber go only so far. I believe its +/- 2.75 degrees of rear camber but I'm not sure.
Also what color scheme are you going?
Give us more details so we can throw you some ideas.
Old Jan 30, 2012 | 03:06 AM
rkuemmer's Avatar
i already have front and rear camber kit for it and couple other things to replace the oem to hold up agaisnt the stance look and i am looking for options for the car if i dont like them then i wont get it but its hard to find a good rim with the offset i want i been looking for 18x8.5 with a +30mm offset for the front then a 18x9.5 with a +35mm offset. I found Some rota's i would love to have but cant find a dealer that has them at all
Old Jan 30, 2012 | 03:20 AM
domincnTC's Avatar
you dont need a rear camber kit for the rear the stock camber bolts go to -5.
if your looking for rotas go to wheeldude.com
do some research
Old Jan 30, 2012 | 03:25 AM
rkuemmer's Avatar
Originally Posted by domincnTC
do some research
went there didnt have the D-Force rims i wanted. Trust me so far i put about 2 days of search for the coilovers i am going to order then still doing search for the rims i want. i found some raderwerks with a 18x8 in the front and 18x9 in the back with a +35mm offset all the way around but i wondering do i have to use spacers for that type off offset to get a mean as_ stance for it is i am going to lower it about 3" Thanks for the help
I will probably end up with the Trial and Error to get how i want and the color scheme i am going for is kinda similar to others. I did a red/white LeD swap on the cluster and hvac done by Cobaltbravo thats his name on here looks great and the cubby light and everything is red. But i am gonna throw in some Carbon fiber like the cluster Trim/B-pillar and wraping the water in CF with the inside of it black. If that helps
Old Jan 31, 2012 | 12:29 AM
mystik's Avatar
CinSity Scions
2 days of searching is hardly any research when it comes to something like coilovers and wheels...ive been looking around for months waiting for good deals to come by until i finally found what i was looking for...i shopped for coilovers for a few months before i decided on a set...as for wheels, i looked for about a year before i bought my 1st set
the one thing about the whole "stance game" is trial and error...youll only know what you like and what youre willing to settle with when you try it...some people rub with 8 inch wide wheels and call it a day...others try to fit 10 inch wide wheels and dont care if they rub...i have 18x9's and i want to go wider...
judging by what you sound like you want...8" wide is not wide at all... at least 9" would be better with much lower offset than 30...probably around 20-30 on a 9" wheel would get you the look you want...
seeing as how youre 18 and probably on a budget...try looking at Rotas, XXRs, Miros or a set of used quality wheels (BBS, Work, Rays, Volk, SSR, etc). or if youre budget is higher, look to buy brand new with custom offsets. if you order custom though, expect at least a 3 month or more wait time before you even see your wheels.
I have the B&G coilovers youre getting...theyre great and I love them. mines been on for 50k miles and still works just fine with no damage and no signs of corrosion or rust
Old Jan 31, 2012 | 12:30 AM
GUNNIST14's Avatar
Sounds good but I mean what color is your car and what color wheels do you like.
Old Jan 31, 2012 | 12:33 AM
GUNNIST14's Avatar
do some research
I stand corrected when refering to stock camber degrees.
Old Jan 31, 2012 | 12:48 AM
rkuemmer's Avatar
My exterior is black about to get it repainted since its still the 2005 paint job and have some imperfections that i cant stan looking at any more. I found rims i really want but cant pick between a black lip or polished lip. I like them both but not to sure
Current look of the Car if this helps
rkuemmer's Avatar
Front View if it helps
Old Jan 31, 2012 | 07:44 AM
rkuemmer's Avatar
I found some Raderwerks rims that i like it gives me the deep dish i like and for our lug pattern 5x100 they dont come with a lower offset of +35mm all the way around. Can you give me any info on spacers i can use and what size spacer not to go over not to harm the studs and some suspension parts since this is my daily driver.
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
Squishface
Sep 15, 2015 06:51 AM
djcezile
Apr 23, 2015 06:46 PM
killahXB2
Mar 27, 2015 10:45 AM
yamahamx117
Scion xD Suspension & Handling
Dec 25, 2014 01:54 PM
