Probably buying axis mod 7s...
Old Apr 17, 2006 | 05:43 PM
Smoses799's Avatar
Default Probably buying axis mod 7s...
Well, im buying some axis mod 7s. However, my tc has the hotchkis drop and these are 19x8 rims. Does anyone know if they will fit or if ill have rubbing? Also, there is some curb damage to them, however i was told that this could be repaired. So, ill probably do that. Anyways, what do you all think?
Old Apr 17, 2006 | 09:31 PM
ScionBandit's Avatar
sIcKsCiOnS
DelMarVa
Scion Tuners
should be ok, ive seen those on cars with more of a drop
as far as the curb damage, where is it, do you have a pic?
i had those wheels in 18s, and depending on where the damage is, it may not be able to be fixed
Old Apr 18, 2006 | 01:55 AM
tinybigrig's Avatar
youll be fine, will fit all day long. you can run a 19x8.5 up front and a 19x9.5 in the rear, so itll be fine with 19x8s all the way around
brent
Old Apr 18, 2006 | 09:09 PM
pitcrewmotorsports's Avatar
Default Re: Probably buying axis mod 7s...
Great rims. I put them on a Acura TL. I love the Mod 7s.
Only problem I can think of is if you put a "Big Brake Kit" It might not clear the caliper. So make sure you know what you want to do as far as "braking power". We had to get extended wheel studs to clear the caliper on the TL.
Pain in the butt but well worth it when it comes to how it looked afterwards.
Good luck!
Old May 3, 2006 | 08:12 PM
ryanclemens's Avatar
good set of rims, they will look great on your car. I almost got those myself. Ended up getting the Axis Crux.
Old May 4, 2006 | 02:53 AM
Smoses799's Avatar
got the rims... http://www.scionlife.com/forums/view...6700&highlight
still need to add some new pics. tinted the taillights and headlights over.
Old May 4, 2006 | 04:46 AM
whitehb's Avatar
those are great rims
wizdumb
Feb 26, 2015 09:22 PM
XBEEZY
Scion xB 2nd-Gen Wheel & Tire
Feb 21, 2015 01:38 PM
Ramroids55
Jan 16, 2015 02:42 PM
Besk_one
47
Nov 23, 2003 10:03 AM
