Quick question about TC Rims
Old Jun 16, 2010 | 08:24 PM
gp1817's Avatar
Default Quick question about TC Rims
ok, i brought my car to a local shop to get my new tires installed,
when i picked up the car i noticed something felt different meaning the car felt heavier,now i know its not the new tires cause ive already went through a set and i know how it felt last time i got it,could it be that the shop over tighten my lug nuts reason why i mention this is cause a buddy of mine brought his to the same shop a few weeks ago and the car just felt different for some reason when he picked it up,felt sluggish everything was correctly installed,so he had the lug nuts checked out he thought maybe there were to tight and he was right,he had it check out and it was torque to 85 lb.....now i dont know if that would cause the problem, but im experience the same problem,car feels heavyier and sluggish almost like i have 50lb of extra weight in the car...w
so would over tighting the lug nuts cause any issues
Old Jun 16, 2010 | 08:27 PM
jono06tc's Avatar
no... its probably in your head
Old Jun 16, 2010 | 09:09 PM
gp1817's Avatar
thats what i was thinking,at least i hope,but i just thought maybe over tighting them will cause a issue
Old Jun 16, 2010 | 11:01 PM
Griever's Avatar
Could be the tire pressure
Old Jun 16, 2010 | 11:02 PM
Frizz's Avatar
Team ScionTific
+1
Old Jun 16, 2010 | 11:04 PM
tin's Avatar
tin
Did they actually balance your wheels after? They could of just kept the old weights on.
Old Jun 16, 2010 | 11:26 PM
draxcaliber's Avatar
lol...over tightening lugs making the car heavier or slower...wow...how would you even rationalize that?
Old Jun 17, 2010 | 12:01 AM
my06tc's Avatar
interesting thread...........check the tire pressure most likely they put in too much air,and no, over tightening the lug nuts wont do that,not sure about your buddies car but that wasnt the issue
Old Jun 17, 2010 | 03:41 AM
jwallace045's Avatar
My wheels are always torqued to 100 ft/lbs lol 32psi in front and 29 in rear. GL
Old Jun 18, 2010 | 12:13 AM
that is too tight. i think the specs are around 85-90 lb-ft of torque. lose nuts fall off, over torqued leads to damage.
also, be careful not to over tighten wheel locks, they can crack under the stress and be difficult to take off.
Old Jun 18, 2010 | 12:57 AM
my06tc's Avatar
i thought the stock lug nuts are suppose to be torqued to 76 lb-ft,thats what mine are
Old Jun 18, 2010 | 04:20 AM
sciontc_mich's Avatar
and you would be CORRECT! It is 76ft-lbs, not 100ft-lbs. And to those who want to say it doesn't matter, good luck with warped brake rotors/discs in the future.
Old Jun 18, 2010 | 04:21 AM
well it's simple. What tires did you get? tell us and we can find how much each tire weighs. If it weighs more than stock, then that's why it's sluggish! Heavier tires = more weight = more power to move tires = suspension is weighed down by heavier tires = unsprung weight.
S7ephavs
Mar 22, 2015 12:09 PM
GoodVibes
Scion xB 2nd-Gen Wheel & Tire
Mar 3, 2015 09:47 PM
TwisTeD_ScioN
10
Sep 22, 2004 09:32 PM
BLKTOYBOX
10
Mar 2, 2004 08:36 PM
tenten
Nov 24, 2003 04:52 AM
