raceland coilovers . does 19"rims fits ? what offset would be the best
Actualy I have H&R springs and stock rims. but want to change them with raceland coilovers set.
soo I am confused bout rims size. does 19* rims will fit ( any rubbing etc ?) Do You have some experience or sugesstions ?
if not I will look for 18" and another questions.
IF 19 or 18 will work with raceland kit what tire size You suggest ?
I was thinking about some 225 front and 235 reaer if possible ?
what offset will be the best to raceland kit. I dont want rubbing etc.
sorry for many questions. And Thanks for any answers.
yes 19" rims will fit with raceland, any other brand of coilovers and springs, all depends on the offset and width of the wheels that you plan on getting. if you rub then your gonna have to roll the fenders and maybe remove the fenderliner from the front wheel wells but that all depends once you've lowered it on the coils and gotten the wheels. as for your tire sizes i would have to say 215/35/19 front and 225/35/19 rear if you plan on slamming the car. as for the comment above you can still rub on 18"s depending on the wheels (width/offset/tires) you get.
if 19 would fit I am thinking about those rims :
konig heatsink 19"
offset 40
rim width 8
tires front 225 /40
rear 225 or if possible 235
here are these rims
http://cgi.ebay.com/ebaymotors/19-Ko...item2a065647d7
if 18 :
konig crosshairs
5x100 18-8 5-100 ET40
front tires 225 rear same or 235 if possible.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
how U think guys ? whats your suggestions.
fender rolling is the last thing that I want to do but if i will have to i will do it. ) and want to keep my splash :D
konig heatsink 19"
offset 40
rim width 8
tires front 225 /40
here are these rims
if 18 :
konig crosshairs
lowered 19"
I have TRD springs with 19's. i only had to cut a lil bit of plastic and roll my fenders in the rear. i only had some slight rubbing with me in the car but with it loaded with 4, BBBAAAADDDDD!!!!! it was rubbing around every corner and bump. I have 19x8 with 245-35-19 nexen n3000. hope everything works out for ya.
i hate posts like this.
you can fit 20s on a tc with rl coils...just dont dump it.
the big question here is HOW LOW DO YOU WANT TO GO!
im not mad at you, but it seems whenever a post like this is made, the OP forgets to say how low they want to go. We cannot help you unless you tell us that.
now if you want to slam and not roll fenders. go 19x8-9 with an offset of +40 or higher with a little camber if needed.
if you don't want to slam but still want like 1 finger gap then go 19x8-10 with an offset of +35 or higher with a little camber if needed.
if you want a some low like 1-3 fingers then you can do 19x8-10 with w/e offset you want and no camber because you'll never rub and you'll look like a retard because you'll have wheel gap.
did i cover it all?
also...19's and rl coilovers...i did a small search for you: go about halfway down
https://www.scionlife.com/forums/sho...62624&page=205
did i cover it all?
offtopic...dq,i love your wheels and your dog too!haha,miss my pits:<
@dj_bad_boy-yea theyd fit,im on racelands with 19x8 et.32 and I don't rub too bad so you should be safe with your choice. nynctc gave you nice lil link.if you wanna go lower,like dq said add some camber and dump it!!
royder1976
10-08-2003 03:12 PM
