Thanks! The front was fine and can go much lower but the rear had both perches removed and is completely maxed out. However we found out that my coil overs accidentally had a 150mm spring instead of the 140mm so they gave me the springs and I just haven't gotten around to installing them yet but then I can put a collar back in and not droop as much at the same height I'm at now
I see. I just got mine and was just trying to figure out where to start with them. I have one perch off of my current set but since they all differ trying to decide so I don't have to take them off again. Where did you get your shorter springs from?
I'll double check the springs in the garage when I get home and let you know. I doubt they are 200mm. You wouldn't get very low with those on haha
Without a good amount of pre-load. I doubt they're 200mm either, I just haven't unwrapped them. If so might be a good reason to make the trek from Orange County to an AutoFashion meet and pick up some springs from B&G.
If you come down to an Autofashion meet let me know. I'm at almost all of their Waddup Wednesday meets
trdscion, which version of b&g did you get? First one had 200mm springs up front and 2nd had 180mm. Rear has always been 150mm. I was trying to get shorter springs from b&g when I had them 2 years ago and was told 150mm is the shortest they can do. I ended up getting 140mm 10kg/mm springs from BC and swapping b&g rear 150mm springs up front.
I got them yesterday and haven't been able to look at them. They were toeveryhour's so I don't really think I have to worry since she was really low.
I'm going to take a look at them today so we'll see I guess.
You'll be fine. Mine were the same as hers, factory B&G specs or whatever. You can have the front at rim and the rear tucking rim by removing perch rings. I also modified the top hat. Devon (Iheartzombies) showed me that you can take the top mount of, basically flip the positing of the washer and it gives you another 1/2" or 1/4" of a shorter coilover up front. Any little bit matters when you're that low.
was at the import alliance fall meet in tennesse not to long ago an saw this tc on rotiforms and also saw "dimebagged" tc as well with that fresh paint! but dont mind the date on the pics had took the photos with my homies camera and thats just what it was
Rim Brand: CCW
Rim Style: LM5
Sizing: 17x10f 17x11R
Camber: F:1.25 R:5.50
Tire Size: 215/40F 235/40R
Tire Brand: Falken
Tire Style: FK452
Dont mind my scraped and not matching lip. Fixing that and going lower after winters over.
Rim Style: LM5
Tire Brand: Falken
Tire Style: FK452
