Speedometer calibration
Originally Posted by garabaldy
How do you adjust the speedometer when installing larger diameter wheels and tires?
if I understand it correctly., straight and simple answer is yes.
1 step up in rim size, i size down in aspect ration.
you are 2 steps in rims 17-19's, and down 2 steps, 45's to 35's in aspect ratio.
If i am wrong PLEASE correct me, as this is the rule of thumb i have been going with for years..
Originally Posted by TongMan
Am I still the same if I went from:
17" OEM rims w/ 225/45/17
to
19" Enkei RS7 rims w/ 215/35/19
to
215/45/17 (stock tC) = 24.62"
225/45/17 (your 17) = 24.97"
215/35/19 (you now) = 24.70"
All close enough that most peeps need not be concerned.
So the 19" rims w/ 215/35 tires are actually smaller than the 17" rims w/ 225/17 tires?
Also what if I get wider tires for the 19" rims like 225 width? What will that do?
225/35/19 = 25.2"
What would happen? Your car would be a bit slower in acceleration, and have slightly higher top-end (unless the limiter stops it). The handling might remain the same, because of the added sidewall height conflicting the the improvement brought by the wider contact patch. The larger tires would also weigh more, and I'll bet your 19's already weigh more than stock anyway.
you guys are making this too complicated. The link below is a tire size calculator. Input your present tire size and then after that input what tire size you are going to. It will tell you how far off your speedo will be.
http://www.1010tires.com/TireSizeCalculator.asp
07tcscion
Oct 8, 2015 05:42 PM
Blunderbuss
Oct 8, 2015 04:56 PM
17, 18, 2254517, bigger, calibrate, calibration, fit, harrisburg, pa, rims, scion, scionlife, speedometer, tc, tires
