tC Painted Stock Rims
Old Aug 13, 2010 | 05:25 PM
  #2561
tCjosh's Avatar
^^^ ya thats what i was thinking too... my wife doesnt like the color so thats why im thinking of changing it... well i also think that if i get everything fixed on it (i.e orange peel like a mother, paint is already chipped and it has no shine) she will like it more and with the polished wheels and oem front it will look alot better...
Old Aug 14, 2010 | 12:37 PM
  #2562
GammaTNT's Avatar
i went to my high school friend's shop to get new tires installed. His worker left 2 scratches on each wheels!!
Maybe the dulicolor paint sucks? or his worker just bad at installing tires? I waited 6 days for the paint to cure.
Old Aug 14, 2010 | 01:22 PM
  #2563
KillerxTC's Avatar
so i painted my rims the other day and my rims came out no where i expected they are pretty bad plus i found out my rotors are completly destroyed and need to replace brakes. dont know what to do about rims should i sand them completly down and retry? rather just get them sandblasted does anybody have any advice??
Old Aug 14, 2010 | 11:39 PM
  #2564
wlfpck's Avatar
Following steps for painting wheels.
1) take off wheels
2) wash wheels
3) let wheels dry
4) wedge index cards in between the tires and the wheel itself
5) spray on the bulldog adhesive promoter
6) light coat of paint
7) let dry
light coat again
9) let dry
10) light coat
11) let dry
12) light coat
13) let dry
14) clear coat
15) let dry
16) clear coat
17) let dry.
1 wet sand with 2500 grit sandpaper
Paint and clear coat should be sprayed on lightly to prevent paint from running.
You're best option now is to use a coarse sandpaper to put some gouges in the current paint on your wheels and to get the clear coat off. Then follow the above steps. The bulldog adhesive promoter in my opinion is extremely useful.
Old Aug 15, 2010 | 12:30 AM
  #2565
yellowxhoodie's Avatar
post some pics
Old Aug 15, 2010 | 01:11 AM
  #2566
CreationBeyondRecreation's Avatar
x2
Old Aug 15, 2010 | 01:08 PM
  #2567
wlfpck's Avatar
http://cherrybox.scionlife.com/forum...17853&page=122
First post on that page.
But more pics...
Old Aug 15, 2010 | 03:08 PM
  #2568
GammaTNT's Avatar
nice job. how long do you wait between each coat?
Old Aug 15, 2010 | 06:09 PM
  #2569
BRUIN's Avatar
Hey whats the best paint for the most black glossy look? I used duplicolor "Satin Black" but it didnt come out glossy.... Should i wet sand them and just redo them in Satin and add clear? Or is there a better paint?
Old Aug 15, 2010 | 07:57 PM
  #2570
just clearcoat them...
Old Aug 15, 2010 | 08:22 PM
  #2571
BRUIN's Avatar
Do you think i should sand them before i paint them too? Also u think the clear is gonna make them hella shine?
Old Aug 15, 2010 | 08:36 PM
  #2572
Dizzzle's Avatar
if you use dupicolor acrylic clear and do 3-4 coats they will look like they are wetter than wet.
lightly sand before you paint. Make sure you use a good primer also.
Old Aug 15, 2010 | 08:50 PM
  #2573
BRUIN's Avatar
What if i just use the paint that is on there (duplicolor satin) sand that down . Then re do it satin and add the clear.
Would that be wetter than wet :p i shouldnt need a primer if i already have paint on there
Old Aug 15, 2010 | 11:24 PM
  #2574
Dizzzle's Avatar
eh, Primer will just help the paint have a surface to stick to plus prevent rust.
Old Aug 15, 2010 | 11:41 PM
  #2575
if you sand correctly the paint will stick just fine.
if you paint correctly the rims wont rust.
Old Aug 16, 2010 | 12:31 AM
  #2576
BRUIN's Avatar
Sounds good! I will post next weekend when i do them again!
Old Aug 16, 2010 | 03:48 AM
  #2577
Dizzzle's Avatar
Getting mine sand blasted and powered coat soon ...
Old Aug 16, 2010 | 04:05 AM
  #2578
thats a waste of money
Old Aug 16, 2010 | 12:28 PM
  #2579
wlfpck's Avatar
Using the bulldog adhesive promoter pretty much eliminates the need to sand the OEM paint on the wheels off.
Old Aug 16, 2010 | 06:30 PM
  #2580
divisii's Avatar
KillerxTC, rim paint is not impervious to damage.. it'll happen eventually.
I did exactly what wlfpck did, I still wish I'd done a third coat of clear.
Dizzzle, um rust? Are you saying corrosion/damage of the clear, paint, or the ALUMINUM wheels?
