Thanks for the help PICS SOON
I am getting 19x8" rims with 225/35/19. I have offset choice of either 35mm or 45mm. WHICH one? I need your help guys. I am lowered on Hotchkis lowering springs I need any help you guys can give thanks. I want to make sure i dont have any rubbing at all. The tire wont be changed I need the 225/35 due to roads in CO. Thanks again
45mm because according to the tC faq site, our stock rims are 45mm.
http://home.cfl.rr.com/icdedppl/faq.html
+35 is more outward than +45. if you want to be safe, go +45.
i measured and will be doing 8.5 with 245, front +40, rear +35 but rolling fender.
http://www.yoursciontc.com/forums/in...howtopic=12153
everyone says 35mm but all tire sites recomend the 45mm offset. I DONT want to roll any fenders. I am loosing 13mm on both sides of the wheel from stock thats a half inch on each side. With 35mm i am 3/4" farther toward the fender lip. Explain how 35mm is less prone to rubbing
if you are worried about rubbing against suspension, do less offset, if you are worried about rubbing against fender do more offset. i wouldn't worry about rubbing against suspension until you go over 9 inches wide rims or use extremely high offset.
again, if you want to be safe and no fender rolling, +45 will fit, i am willing to put money on it.
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
02-29-2016 05:39 AM
