Tire size choices
Old Jun 26, 2020 | 01:14 PM
backroad101's Avatar
Default Tire size choices
I am in search of new tires. The car has 160k miles on it and is basically a beater car to and from work (which is 95% highway). That being said, my main factor is price really. In that, I am exploring different than OEM sizes as options in addition to the 215/45/17. Here are the sizes I am looking at
215/50/17
225/45/17
Pros and cons of either? Would you choose one over the other? Is there a size not mentioned you would consider or are currently using? Again, car is used 95% highway and is the stock ride height.. Also not too concerned with the speedo be off a little
Old Aug 24, 2020 | 07:06 AM
MR_LUV's Avatar
Administrator
Administrator
215/50/17
225/45/17
Take a Look at Sticky tC 1G Wheel, Tire and Offset Calculator
and the other Stickys in the Scion tC 1G Wheel & Tire Forum Header Above your Thread to get an idea.
MR LUV
__________________
Old Aug 30, 2020 | 03:24 AM
alxm's Avatar
Moderator
Moderator
Out of those two optional sizes you mentioned. The only one I would consider is the 215/50/17. The 225/45/17 will increase the contact patch area and increase rolling resistance. This will affect your fuel efficiency negatively. Probably not a lot but it will. The 215/50 will increase the sidewall height which will give you a softer ride as the sidewall will be able to deflect bumps more. But in turn it will give softer handling on the curves.
I personally would stick to the OEM size and look for a tire with a high UTQG rating and proper load and speed rating. Our recommended load/speed rating is 91H. The higher the UTQG rating the longer the treadlife of the tire. I also usually am a low cost tire shopper as I drive a lot and can't be constantly replacing low treadlife/high cost tires. Two sites that I usually buy tires from are Onlinetires and Simpletire. You can do some research on those sites for the tires in the size you want and see their ratings and reviews.
215/50/17
225/45/17
alentz627
Aug 6, 2013 02:38 AM
scrossmaggard
Scion xB 2nd-Gen Wheel & Tire
Feb 28, 2009 11:25 PM
Desnudate883
Jul 24, 2006 07:17 PM
consecrow
10
Sep 5, 2005 06:51 PM
xb
Aug 31, 2004 01:16 AM
