HID Question
The black and red plug into your head light harness (where the bulb was).
If you have a relay, it plugs into the relay harness instead (and the relay plugs into one headlight harness, the other is not used).
So whats the difference between these Meng/Morimoto kits and the $30 e-bay kits?
I have a set of the e-bay lights in my xB and they are much better than the Halogen. It does have a bit of flicker in one bulb for about 10 seconds after startup, but steadies out after that.
I have another e-bay set in my other car for the past 3 years with almost constant use (they are 3000k fogs, use as DRL) and they are still running strong. Had another set (5000k) in the wifes old van in her fogs and they were fine also for about a year before we sold it.
I spent a total of ~$93 on 3 sets that all work fine, what am I missing with the $120+ kit?
A bit confused with my lights wiring. I know what connects to the ballast and what connects to the relay, I'm confused as to what the other two wires (black and red) are for?
Awesome, thanks. Went to finally install everything today and realized I think they sent me the wrong sized bulb. Isn't it supposed to just click in place like my stock lights do? These ones are a bit too small.
Verify your order if the bulb indicated are H11.
The diameter is small or it's loose? Did you remove the round rubber gromet?
Sent from my thing
The gromet is the circular thing a little down the wire correct? Does it just slide up to be flush with the bulb? I didn't know the rubber part was supposed to go in with the bulb too.
Sori I keep on saying gromet. What I mean is the round red rubber at the bulb housing. Its a bit thick. While installing the bulb, try pushing it in more, then twist to lock it in place. Jut like installing regular halogen bulbs.
Sent from my thingy
I took some more pictures including the bulb closer up so you can see the notches built in and the red rubber and then a picture of the bulb hole taken from the inside (so it's a bit dark, but you can still tell).
Also, I took pictures of my relay wiring, can you let me know if it looks ok?
I guarantee that you aren't pushing hard enough. Those are definitely H11 bulbs that you pictured.
Your problem is that the red rubber o-ring is not seated properly. It needs to be pressed further down, and spread out more. The o-ring is positioned in a way that isn't allowing you to get the bulb all the way in.
Ok, I feel really dumb. I kept taking out the hi-beams and trying to fit the HID's in there. It wasn't until I just realized where the low beams were, and of course when I went to put the HID's in, they fit perfectly.
Sorry for the hassle guys, still a newbie when it comes to doing this stuff.
