Scion tC 2G Aero & Exterior Aero parts and exterior dress items...
tC 2014+ HID (9012) bulb issues
Old May 23, 2016 | 07:12 PM
tC_toph's Avatar
Angry tC 2014+ HID (9012) bulb issues
I bought an HID kit (from TRS) and of course i figured out what size bulbs to get by looking at my OEM bulbs and also by looking at the Philips bulb chart (9012's).. Got the kit and installed it, then I realized the bulbs don't really fit how they are supposed to. The ground wire (coming out of the tip of the bulb) is supposed to face down to the ground and it was facing up (10/11 o'clock position). They are also quite loose, even tried switching out the O-ring from my OEM bulbs and they are still pretty damn loose.
Comparing the tabs on the bulbs they look identical except the big tab is on the opposite side of the bulb of where it should to be.
They told me i need to order 9006's and trim the top tab, anyone else have this problem?
Seems kinda odd to me because when i google 9012 halogens it has pictures of how my OEM bulbs look, and when i google 9012 HIDs it comes up with pictures of how the 9012 HIDs that i got in the kit look like.
Old May 23, 2016 | 08:40 PM
zi0n's Avatar
is this the morimoto kit? I have it with 9012 bulbs and it fits just fine.
Old May 23, 2016 | 09:02 PM
tC_toph's Avatar
Yep morimoto Kit.. Hmm that's weird cause it definitely doesn't fit mine.. When did you get it?
Not loose? The ground wire coming out of the tip of the bulb is facing to the ground??
Been emailing back and forth with TRS for the past two weeks or so and they told me to order the 9006 bulbs.
Thanks for the reply
Old May 26, 2016 | 05:36 PM
tC_toph's Avatar
Man so no one else has had this problem? I have a 2016 not sure if it makes a difference...
Old May 26, 2016 | 06:07 PM
zi0n's Avatar
My last post got moderated somehow...
Anyways:
I got mine from lightwerkz(they are sister company of TRS). Are you using their harness? I don't. I have them connected directly.
Old May 26, 2016 | 06:30 PM
tC_toph's Avatar
Anyways:
Ah, yea their stuff is exactly the same.. I am using their harness and everything, but my problem isn't with the harness its with the direction the bulbs are facing inside the projectors. Also they are not a very snug fit and when i go over bumps i can see the light bouncing which I've read can melt your projectors if you let the bulbs stay loose like that..
Also i noticed in your build you said you have the 5000k bulbs but they don't seem to have that option anymore? (unless you meant 5500k?)
Old May 26, 2016 | 06:45 PM
zi0n's Avatar
Thats weird... not sure what to tell you, mine fit perfectly fine.
I was wrong lol, I got them from TRS and they are indeed 5500k.
I have bought from lightwerkz before so i didn't remember.
Old May 26, 2016 | 07:08 PM
tC_toph's Avatar
hmmm... your sure they are facing the right direction?
The wire coming out of the bulb is supposed to be at the 6 o'clock position inside the projectors.
This is what i need (the tabs are in the right orientation) The arrow is pointing to the wire that needs to face downwards to the ground.
These are what i got from TRS (notice the big tab is in a different spot..)
Old May 26, 2016 | 07:32 PM
zi0n's Avatar
They look fine to me.
I just took it out to take pics for you:
Old May 26, 2016 | 07:44 PM
tC_toph's Avatar
Hmm, yea the tabs on your bulbs are the same as the ones I got from TRS.. But does the wire coming out of the tip of the bulb face to the ground when the bulb is seated into the projector??
Cause if it does face to the ground that would suggest either I'm doing something wrong or my projectors are somehow different....
Thanks for the pictures
Old May 26, 2016 | 09:13 PM
tC_toph's Avatar
well just got the 9006 bulbs from TRS in the mail, the tab orientation looks a lot more promising.. will update with results.
Edit:
Just test fitted them and they literally fit perfect.. TRS said i might have to trim one of the tabs but I didn't which is pretty nice..
The tabs are a bit different but i guess they work.
here is how the 9006 tabs compare to the 9012's (9006 on the left 9012 on the right)
Thanks for trying to help @zi0n
Old May 27, 2016 | 02:57 PM
zi0n's Avatar
No problem man, glad you got it fixed.
pjl52
Aug 13, 2015 02:38 PM
GoodVibes
Mar 10, 2015 04:29 AM
TOY_bB
9
Dec 6, 2003 05:15 AM
TOY_bB
Nov 29, 2003 03:50 PM
deathcabforme
Oct 16, 2003 04:02 AM
